1982 springbok transom replacement..........need advice
fxloot
Can the wood be replaced and can this be done without rivet work ? IMG_0189.JPG
bonz_d
Absolutely! Fasteners can be replaced with stainless wood screws and machine screws. A few more pictures of the transom cap would help determine the best way to get the old wood out.
fxloot
Here's a pic showing corner cap and also just above the wood transom is a strip of 90 degree angle aluminum which is riveted on running full width of the wood which is 8" x 48" transome with corner cap.JPG
fxloot
Ok.....old wood is out....that was easy since it came out in a million pieces...........is the consensus that a new 8x48x1 1/8 will fit in without removing the angle aluminum piece ???old wood out.JPG
bonz_d
I think 1st of all those corner caps are going to have to come off. Next I can't tell how that angle piece is attached that goes along the transom. If it's riveted remove it. That can be put back into place with stainless machine screws from the outside.
TruckDrivingFool
That riveted strip is high enough that I wouldn't even be afraid to pop rivet it back in place and seal the heads with some 5200.
fxloot
No Title
Job done thanks for your suggestions......
fxloot
Now i would like to replace a few rivets on the floor............the rivets given to me are solid aluminum with a 1/4" diameter and marina man says use 2 hammers.......i'm NOT that good at the aim with a hammer so would like to get a rivet gun........any recommendations or pic's as to what i should be buying............cheers
TruckDrivingFool
If you already have an air compressor you can piece meal a rivet kit together for roughly $50 (w/o shipping) - air hammer, rivet set, bucking bar of your choice
By the time you get shipping on all of the above, it may be just as cheap to get it all from amazon though check out the frequently bought together - here
I will say that after a few trial rivets in some scrap I found one of these nice for my air hammer just to give it a bit better adjustability
