bleedblue94
Thread starter- Joined
- Oct 11, 2010
- 272
motor has run great lately, but in the last week became very hard to start, would seem to load up on fuel and hesitate on hole shot, and then became almost impossible to idle. now, it is clearly not running on all cylinder at all times. yesterday when it died at the dock i pulled the plugs and all were black and wet. i did not have any fresh ones with me, but i cleaned and dried the ones i had and the motor fired right back up and worked fine. i took it out for a short ride and then when i went to idle again the motor slowly ran worse and worse until it eventually just died out. i do know i am due to rebuild the carbs, and plan to do so this weekend, but the spark appears weak on all 6 cylinders. it is not likely i have 6 coils dying out at the same time, but i would think it is possible to have 2 power packs dying a slow death w a motor this age. i am curious if there is anything else i should immediately check that would have an affect on all six cylinders? poor ground was one thing that came to mind but grounds appear to be clean and healthy.
TIA
TIA
