1983 7.5 hp merc water pump for .438"shaft
kazek
hi.recently i have purchaced 1983 7.5 hp kicker motor,sn#6240895.after compression and spark turned good.now...when changing impeller found that it was a miss fit(47-89981).it had lots of play by the shaft,water pump base is melted inside by the cupandthe water intake is almost blocked.i dig into it more ad found that i have .438" shaft and cannot find replacment pump complete kit.my water pump base has 46-92969 satamped on it and i can't find replacment.www.mercruiserparts.com lists housing 46-92970a1 to fit that shaft with impeller #47-89980.does sierra makes complete kits for .438 ..or i have to buy housing,seals,o-rings etc.separetly?any thoughts on nthis are appretiated041.jpg040.jpg039.jpg
Laddies
Banned
Re: 1983 7.5 hp merc water pump for .438"shaft
The kit is NLA from Mercury also but you can buy the parts individually
kazek
sierra 18-3446 has replacment kit for .456"shaft.would housing fit smaller shaft with change of seals(18-2110 for the cover,18-0516 for the base) and a impeller 18-3054?why is that there is NLA parts for those motors
Laddies
Banned
The housing you need is Mercury part number 4692970Ai buy which ever one you like. As far as NLA you could write a letter to Mercury Marine as I can not speak for them.
kazek
Ok.thanks laddies
oldman570
Check your PM's as I might be of help
Oldman570
