1983 Blue Fin 16’ Resto
83bluefin
Oldest passed his NYS Boater Safety class yesterday. Hopefully get back on the project this week…been too cold & rainy to work on it in the driveway.
airshot
That stinks not having some place indoors to work on your boat, mother nature rarely cooperates.
83bluefin
It is what it is. Until I hit the lottery and move out into the country. I have 0 space on my city lot to build.
Pretty much on my checklist before I switch gears to getting our main boat ready for the season….
*remove/replace first keel roller on trailer as it’s only partially held on by the shaft atm.
*finish painting trailer
*paint rims
*replace tires
*finish removing all stickers
*Gluvit interior - I sprung for the good stuff
*fill all unnecessary holes with Marine Tex on gunnels
*pull the pitot tube and electric paddle wheel, reseal with ss bolts/5200
*replace rotten piece of trim that supports front bow aluminum
*paint boat
*install “new” windshield
Then tarp it for the summer and work on it as time/$$$$ allows.
Won’t make it to the water this year. Next year looks doable.
Still will need full floors, trim panels, both dashes, front casting deck w/storage, rear seat build, all pedestal seats installed, complete wiring package, kids want a bluetooth stereo, and Seadek/Hydroturf/Amazon special decking. Ohh and a modern 4 stroke…gotta do some evals on the Yammie, Honda, and Suzuki. Merc is out…I just don’t want one.
83bluefin
Started the tedious task of breaking down the “new” front windshield for paint. Got a couple answers to my previous questions…
My oldest was 100% correct in that there was foam weatherstripping between the front and side panels where the (3) philips head screws joined the parts. Looked to be maybe 1/16 to 1/8 thick? Will source something. Might even go the inner tube route…hmm……
Also, where the channel is attached to the hull there is a thin rubber gasket. Bicycle innertube will work for this. Some spray adhesive to adhere it to the channel and a very sharp X-acto knife to trim the excess.
Beyond that…not happy how the wire wheel cleaned up the flaking paint. I set the one front panel section in etching primer and I can tell where bare metal was vs layers of paint. Nuts. Going to have to see about an electric DA sander and some 220 grit sandpaper. This is going to set me back a touch…
Bugzilla46310
I put a 6” wire brush on a 4” angle grinder. It’ll take the paint off no problem. But wear leather gloves as it works well in knuckles too. It also works the grinder so I don’t overdo it. I also have a larger angle grinder with an 8” wire brush, but that’s a bit overkill for what you are doing. The smaller wire brushes used in the drill like your picture don’t have the grunt for what you are doing.
83bluefin
It got alot of the loose stuff off. You know the stuff a 3yr old finger painted on? Yeah that stuff. There were a few spots though that were actually adhered and that’s what is causing the issue.
I was trying to go gentle so as to not scratch up the aluminum channel too much. Apparently I need to get a bit more aggressive.
I have an air powered DA but my compressor has issues keeping up with the demand. Turns out my HF sander is a DA so I’ll just restock on sandpaper and buzz through the frames.
May go down the rabbit hole of spraying epoxy primer using my hvlp gun. In for a penny, in for a pound…
Would need a very nice weekend with no wind. That’s rare these days.
MikeSchinlaub
FYI, a DA, or dual action sander, is a random orbital sander with the ability to lock the shaft, turning it into a straight circular sander. That makes it much more aggressive, basically a grinder.
What you have is probably a random orbital sander, which is plenty for the job. Those windshields are usually powder coated, shouldn't be too much trouble.
83bluefin
Painted. Probably from 70’s or early 80’s based on the flat glass, side wings and visible screws. Most likely off a glasser. My HF sander with 220 made short work of what was sticking up. Acetone was lifting the remnants of the black paint and what I presume to be red oxide primer.
It’s set in etching primer and I’ll give it a few days to off gas before flipping it over and doing the other side.
Modern I’d agree are more often than not powder coated. No debate there. If I had the facilities to do so, I’d powder coat it as well. But since I don’t, Rustoleum will work fine. The etching primer had quite the grip on the old paint and frame so I feel confident in the steps forward. Color then a couple coats of clear.
Need to purchase a couple of the rotating window locks for the walkthrough. And a couple bumpers for the window frame…previously it had plastic stops which are busted and one rests on the glass which I don’t like.
83bluefin
Coat #1 last night. Coat #2 followed then I removed the masking as I need to flip the panel over, re-clean, etch, then paint.
Need to eventually measure for the window support bar. Then purchase replacement pair. It didn’t come with any, there is a single screw hole where one should be, and the ones in the boat on the current windshield are gross. No saving them.
83bluefin
Other side done. Gave it a couple passes with the sander followed by lots of wipe downs with shop rags/acetone. Then a few coats of primer then color.
Gonna have to do a small section of console in the EZ Poxy Blue Ice to see what it’s going to look like.
83bluefin
Good news! While removing the rotten bow support I found the capacity plate. Says I can go to a 90. Hmm……16’ boat with a 90….hmmm….
I will need to adjust both consoles for the new windshield so…how would you handle this mess? Anyone got a good source to repop one of these?? Because to put it back to factory, I don’t think I have the steering cable length.
Fwiw…the starboard side is sitting down about an inch from the gunnel whereas the port side is sitting down about a half inch. Both have a slight taper in the tops to account for the slight arch in the bottom of the existing windshield. New one is dead flat so I’ll need to adjust it a bit or shim.
