1983 Deck Boat Transom/deck/stringer replacement Help
Decker83
Re: 1983 Deck Boat Transom/deck/stringer replacement Help
I put the fuel cell box on top of the 2 center stringers using PB as glue. I then put a layer of 1.5 csm and 2 layers of 1708 over the side of the stringer and over the top of the box. As you can see in the pic.
I did get 3 of the bulk heads in on one side of the fuel cell box. I used the zip lock bag and laid in the PB and was able to put 1 layer of 1.5 csm on them. I did pre soak the plywood before I laid the glass.
The last pic isn't very good. It was dark and I had the work light shining down on the work.
Hope everyone had a good weekend.
Trooper82
Holy cow, that is looking like a boat.
Looks like a quality job decker. Very nice indeed.
rrumba
Ensign
Nice job decker. it is coming along quite nicely. excellent looking glass and fab work. Sorry have not posted it awhile but i have been keeping an eye on your progress.
sphelps
The work looks great Decker, Looks like ya got all the goody out of the weekend! She's gunna be rock solid!
rickryder
That's awesome! Fine job Decker!
Jon Sob
Excellent work my friend ...... great job!
Woodonglass
I think when you get done, you'll be able to use this as a Marine Landing Craft!!! What a TANK!!!! Your attention to detail, excellent craftsmanship, and dedication to "Doing it Right" Is really showing up in this project. This will be the standard for Deck Boat Restoration on iBoats when you are done.
Trooper82
I realise it may be a little late, but I agree with Wood on this one. "Your attention to detail, excellent craftsmanship, and dedication to "Doing it Right" Is really showing up in this project. This will be the standard for Deck Boat Restoration on iBoats when you are done."
Been a couple weeks. Got any updates?
bear_69cuda
Hey Decker,
Man, you do super high quality work... PRO all the way!
Ditto on all the other iboater comments!
I bet you can taste the finish line now!
Decker83
Hey everyone.
First I want to say a BIG THANKS to each and everyone of you guys that have took the time and made a effort to read my thread.
Your comments have all been great and helpful to me. I really appreaciate the fact that you all have took enough intrest in this thread to comment. Thanks to all of you.
Did get some more work done in the last few days. Have some new pics to share.
Here I put in 3 more 2x2 top rails for the bulk heads.
Here or 6 peices of the bulk heads.
Here is a pic of 1 of them.
For each bulk head I made 2 peices to span the hull. For the patterns I just took measurements at equal spaces and marked
the plywood and cut it out. Made a few adjustments and went to the next one.
After they were cut I wanted to seal the bottom of the bulk head that is not conected to the hull.
I used the method of tearing the csm into peices and dabbing them with resin. This worked very well.
Decker83
Here or more pics of the bulk heads after sealing.
Got out the ole 7" grinder and all the good protection, goggles zoot suit respirator and face sheild, and did the rough and scuff.
Here is a pic of 3 of the bulk heads glued and stapled in place.
I left about 1/4" between the hull and the bulk head that I will seal with PB. I will use the zip lock bag and squirt it in to fill and fillet the gaps.
Hopefully I will be able to finish putting the remaining bulk heads that I have cut out and have them PB in and all glassed tomorrow.
Thanks again guys for your interest in this thread.
Hope everyone had a productive weekend.
jbcurt00
Man, that's a ton of structure. It all looks great! Well done.
Woodonglass
Decker, that's some mighty fine fabrication. Do you have a splash date in mind yet. Tomorrow afternoon is looking REAL good for me!!!:D
sphelps
All that fabrication on just 2 Dr Peppers and a Mountain Dew! :D
It all looks great Decker, a job well done!
Decker83
I really really really really hope you get to SPLASH tomorrow. We have all been watching and waiting for this.
I have to much work left to do before I can think about a splash date.
Decker83
The boat was built this way when I started the tear down. I did make one change. The bulk heads were on 24" centers and I made them on 16" centers.
Thanks
Decker83
Thanks sphelps.
I have to admitt it was more than 1 Mountain Dew :eek::eek::D
rickryder
Really nice work on those bulkheads Decker....like the way you sealed the edges too!
Jon Sob
Hey Decker ..... you sure do nice work. Great job.
Decker83
Thanks rickryder. I don't remember where on i-boats I found that trick but it sure does work well.
