1983 Deck Boat Transom/deck/stringer replacement Help
rrumba
Ensign
Re: 1983 Deck Boat Transom/deck/stringer replacement Help
Hey Decker,
i do not think the poly will stick to well to the bunnies, but let me know how they work out, that will be cheaper than 1708.. :eek:
Decker83
Hey Decker,
LMAO I don't know if it will stick to them. I'm just to old and slow to catch one. :D
Jon Sob
Just checking in to see if you have any updates ...... hope things are going good down there.
bear_69cuda
Hey Decker...
I really wanted to read your build today, but all the images are not viable for some reason???? Anyhow sounds like a great build, and I hope I can view things soon! Maybe it's to do with the issues on the forum lately? I've subscribed regardless! Have a great weekend!
Friscoboater
I think the images are gone for good.
Decker, try and host them through photo bucket like i do, and you will never lose them. It is very easy to do, and there is a stick on it in the adult only section.
Decker83
Need help with photobucket.
How to post
Woodonglass
In photobucket, when you hover over your pic a window will appear and the bottom link (IMG Code)is the IMG link. Click inside the white box and it will say COPIED. Return to iBoats and Paste this copied link into your post where you want it to appear. Very simple and easy.
Decker83
Thanks WOG.
I will try again.
Are all of the old pics just gone now.
Decker83
Hey Guys,
Was able to get some work done this weekend. Nothing to brag about.
Looks like the pics are working again. :D:eek::).
Maybe this next weekend will be better.
Jon Sob
Hey Decker .... this time of year any work is worth bragging about.
Decker83
Have a question about the gas tank hose. On the large hose to fuel the tank, how tight of a radius can be made without doing damage to the hose.
I never have used this type of hose and don't know what type to buy. I know I need the kind that can handle the new gas/alcohol fuel.
Does it have a wire inbeded in it or just rubber.
I need to make some tight turns to install the belly tank.
Any help will be appreciated.
Did some work today. Will have pics up tomorrow.
Hope everone had a good Saturday.
Trooper82
Decker - I would think that as long as you can get around your corners without a kink you'd be good. I know the fill hose on mine was pretty stiff. Luckily I have no corners to navigate. Can you move your filler inlet somewhere else to aid in not having bends? I don't think mine had any wire in it, but it could.
Looking forward to the pics of your progress.
Woodonglass
Check into getting one that has the curves you need already made. I'm looking for the link in my library to the MFG of the filler hose.
What diameter are you looking for?
Found it...
http://www.tridentmarine.com/stage/fuel.htm
they make corrugated so it will make tight bends.
Decker83
Had some nice weather this weekend for a change and I took advantage of it.
Took the 2x2 cedar rails I made for the port and starboard sides and wrapped all four sides with 1.5 csm. This took alittle time but worked out good. I used some string lines from the bow to the transom to have a guide to set the rails with. After alittle ruff and scuff
on the rails and the sides of the boat I mixed up about a pint of PB and started to set the rails. I used the brass screws I removed from the old rails.
I then took the cross rails ( for lack of better name) and put one in the bow and one in the stearn. I marked the center line on the top of each. I found the center line of the transom and the bow and ran a string line from each center mark. I also used this line to make sure I was at the correct height for the deck.
I cut out the first bulk head that goes at the end of the storage box's. I didn't make a pattern, I just took measurements and cut and fit.
I used 2 peices of the plywood and spliced them in. After this I put in the frame I made for the storage box's and the splashwell.
I fit it all in place did some ruff and scuff and started putting in the PB. I used a trick for the PB, I took a large zip lock bag and filled it with my PB. After a few twist I had what looked like a cake decorating bag. I just sniped off just a very small point of the bag and started squirting the PB. I made about a pint for this. It went under the small space I allowed for the bulk head and I was able to do both sides at the same time.
Let me tell you it was 10 times easier and faster than the good ole PL.
Here is one side of the bulk head glassed with the 1.5 and tabbed with 1708.
Hope some the good weather made it your way this weekend.
More to come.
Trooper82
Nice work! Great progress too. I like the idea you had for applying the PB, I will use that when the time comes.
Glad you had a productive weekend, your work really is good.
Decker83
Has anyone dealt with the company Raka Inc before.
Woodonglass
Not personally, but I have perused the Uncle Johns John boat website extensively and they Highly recommend them.
jigngrub
I haven't, but I've heard good things about them on another forum.
They have a UV inhibited epoxy resin formula.
