1983 Formula F20SC
ryanmech
Re: 1983 Formula F20SC
will pull all the plugs tomorrow and replace them I have new ones never got around to putting them in and then throw a new flamethrower II coil that is matched to the new ignitor II distributor bad part is I won't be able to test it :( I have the baby tomorrow and I am working in the am tues wend and thursday is the funeral.
ryanmech
Photos As Promised... there are more on the other camera but it is at my inlaws
ryanmech
Well after posting in the engines forum I checked a whole bunch more stuff and still no difinitive answer so I am throwing half a boat unit(500) at this motor (new carb, and coil) if that doesn't fix it, it will be time for several boat units to take it to the marina and have them go through it
Friscoboater
Just do the coil, and plugs first. I bet that is what it is.
I have lost track of how many boat units I have spent.
ryanmech
I have messed with the carb so much going through this issue that I am going to replace it as opposed to completly rebuilding it yet again
ryanmech
Checked all plugs... new carb... new coil ... new fuel filters... checked firing order same problem
Luhrs28
How about the spark plug wires? An old trick to check them is to run the engine at night, I mean when it's pitch black, and look for any arcing to ground. Many times it will only do it at certain RPM's like you're describing.
How's your dist. cap and rotor?
ryanmech
well heres the status of this project SNAFU so I have no fuel pressure.. well not none but only like 3 pounds...... further investigation shows more than likely the fuel pump lobe on the cam shaft is done in... this is not the end of the world we could put in electric fuel pump. However when I shut the engine off I heard hissing ... wtf is that ... water boiling in the manifolds........ OMG the water line from the outdrive is pulled off so no water.... so we get to see if we siezed her up now...
Friscoboater
Oh man, that is not good. Check the impeller while your at it.
If that lobe on the cam is shot, maybe you should check the lift on the cylinders.
ryanmech
Well after two seasons of working on this boat it is in the water and running two rides so far with no problems .....except owner stupidity.....forgot the plug for the transom an almost sank but other than that ..... all. Is well. Replaced the fuel pump with electric and no more bogging ... time for boating
Cadwelder
Glad to hear it....the forgetting the plug is somthing we've all done. Makes you remember next time, now if you forget it again, we can all have a laugh.
Safe boating to you and your family.
CW
SleekWolf
Man, sounds like you have had the worst possible luck with this boat. At least I know I'm not alone. lol There's one more thing you should check before taking it out again. Chech the history of the boat and see if some old man with a goat put a hex on it. ;) lol Hope you don't have anymore problems! Good luck!
