OBJ
- Joined
- Dec 27, 2002
- 10,161
OK whiz kids.....OBJ having a problem with the titled engine. Idles like a perpetual lean cough. Have done the carb and double checked the jets. Spark is up to specks.....1/2" jump looks like lighting. Check fuel pump....replaced diaphram and gaskets. Pulled the head (compression by the way is 115 on each hole) and the gasket was good....exhaust cover....same.....bypass cover same.
Checked flywheel key and replaced just for chits and giggles. Got a good look at the reeds while the carb was off and could not see any signs of damaged reeds.
I can install a new set of spark plugs and run for about 10 minutes and the plugs will come out covered in carbon soot. Hard to keep it running....have to play with the throttle and sometimes it spits out the carb. (actually had a flame shoot out today....really cool).
Checked under the flywheel to make sure the upper seal was good....can't see any signs of blow out. Nice and dry.
Nothing coming out the prop exhaust...like nasty heavy unburned oil or stuff like that.
Adjusting the low speed needle has very little effect on the coughing, hacking, wheezing, sneezing.
Ain't overheating and I've tried my shop tank.
Free Bud Long Neck to any whole can give a clue.
Thanks...................Jim
