Re: 1984 Cheetah 170 restore
The boat finish is or was really oxidized so this is what i did. I was really pleased with the outcome for as bad as it was i think I am still going to have to get the top section clear coated it is just to thin.
step one bought a porter cable polisher 100.00
step two bought a gel coat restore kit from mcguires i think 25.00
step three bought polisher pad kit included 7 pads and backing plate from chemical guys 85.00
step 4 get to work
it took me about three hours but got about a 3rd of this done
step 5 buffed using a yellow pad and the oxidation remover from the maguires kit Porter cable polisher set on # 5 and slowly made six passes over each section
step 6 polished using a orange pad set and the polisher from the Maquires Kit Polisher set on #4 1/2 made six passes over each section was probably the hardest part cause it was a pain to wipe off in this instance found less is better cut back the amount of polish back and seemed to come off a bit easier
step 7 waxed using a white pad and set polisher on 4 only made about 4 passes on the wax
The pics dont really do it justis but once i get a chance to get it out side in the sun i think it will show alot better
First pic was before i started then after buff then after polish and then after wax
