1984 chrysler 130
pistolp
my boat motor starts and runs but it dose not engage the propeller what could be the problem
pistolp
Re: 1984 chrysler 130
not sure how to do that can you tell me how to check
but when i put it in the water it ran but it would try to go then it would jerk then go the jerk
pistolp
not sure how to check that can you tell me but when i had it in the water it would go the jerk the go and the it just stopped
maxum247
Use the search feature at the top of the page and type in (shift cable adjustment) and search for (clutch dog) also and see if one of these may help!
Seems if your propeller were slipping you would just move along slow regardless of the throttle positon!
jerryjerry05
Check the oil in the lower unit and see if there is metal shavings in the oil or water in the oil.The gears might have gone and it locks up when put in drive.Jerry
