1984 sea ray rebuild (new pics & question)
Ninjafied
i picked up this boat last spring used it for the whole season as is but this year i decide to replace the seats and carpet.
hers a couple of before pics.
hope that worked
Ninjafied
Re: 1984 sea ray upholsty turned rebuild
once i removed the seats and started to pull the carpet i found i was going to be in for more work
now as you can imagine the further i go the more rotten wood i find.
well i might aswell get this over with time to tear it all up
Ninjafied
the stringers were rotted, the foam water soaked.
so far i've got most the major removal done but with limited time and crap weather its taking longer than i hoped
heres a couple more pics of how far i gotten
i hope to have the rest out this weekend. more to follow
bluewavecaptain
Look on the bright side. Now you'll have peace of mind in a job well done. I always have trouble trusting someone else's work. New wood, glass, and upholstery, you'll get another 20 years out of her.
jkust
Thats a nice looking boat for the 80's. Will be great when you are finished.
Ninjafied
got most of the big stuff out between rain showers today, have lots of grinding to do now.
have to add pictures later.
next step is get out the fuel tank out but it's 80 L and full.
i've got an old fuel pump to try and remove the fuel, hope it works
Ninjafied
so the weather here has been horrible ice storm on friday rain every otherday.
had a little break in weather today so i got after removing the fuel tank.
using a fuel pump and battery worked great.
i pulled up the rest of the bottom and got a nice surprise of water and foam under the tank.
i tell ya this demoing of the boat creates a lot of waste
thats a 4' x 8' trailer .
Ninjafied
on a slight side note i broke 1 of the vent louvers.
does anyone know of a canadian source for these?
i want to avoid ebay, i've been burned to many times on cross border stuff.
Woodonglass
Boat Salvage yards, Craigslist, or Ebay. That's about the only place you'll find it.
csray
Nice to see someone else doing the same as me. I also have a 84 searay seville that im totally restoring. I pulled out the motor and and have the floor cut out from the transom to the back of the bow. Should I run the stringers the full length or tie into where there is no rot? I was thinking about just joining it up to the existing stringers right below the dash area. I'm new to the forum and I'm not sure if this is considered high jacking your thread, sorry if it is.
Ninjafied
nickypoo, nice find i ordered 2 this morning. there exactly what i was looking for.
csray, it's your call but if you look at the front pics of my boat you can see that the front of the stringers were not glassed in very well.
you might want to start your own thread and post pictures, theres lots of help to be had on this site.
Ninjafied
there is nothing like a great neighbor, mine shows up this morning with grinder in hand ready to work.
cheep labor aswell, he works for beer and pancakes.
not sure what everyones chose is on grinding discs but i can now highly recommend the fiber discs from diablo.
using a 36 grit today made short work of grinding. probabaly another half day of grinding then the rebuild can begin.
new pics up soon.
Panoguy
I am SO going to be watching this thread - I'm also starting what I thought was going to be cosmetic changes to my 1984 Seville, which is turning-into a full-out rebuild, just like yours!
OH -
Could I borrow your neighbor?? :D
Ninjafied
why does work always get in the way of working on my boat, the first nice day all spring here and i get stuck working 16 hours.
well atleast today in the rain i had some time to start the orngional project, the upholstry.
here a bit of what i had to start with
i think this will be the hardest to recreate, it sits up in back over the engine and back seats.
Ninjafied
look what i found in the bow cushion
no idea what kind of mushroom that is
Ninjafied
and here's a few more side pieces i got tore apart
luckly enough i recieved my samples of material today so the wife and i can pick new colours for the boat
Ninjafied
i think it about time to get some of the materials im gonna need.
3/4 ply for stringers and floor, 1/2 ply for seats 1/4 ply for side trim upholstry.
what i dont know is how much polyerster resin and fiberglass im gonna need, i plan on laying a couple layers on the hull before the stringers which will be glassed in and also the deck will be fiberglass.
any help on estimating the fiberglass and polyester resin will be great.
thanks
Woodonglass
Re: 1984 sea ray rebuild (new pics & question)
Uhmm, does the hull seem to be particulary flimsy? Are you NOT going to be putting the 2 part Pourable foam back in? It's impossible to give an exact "Quote" of everything you'll need but this list will get you "Started" and from there, after you've done some "Glassin" you should have a good idea of what you'll need to "Finish"
Here's the Starting List.
  • PPE
    Respirator (Full Face Preferred $100) if not then double filtered 1/2 face and Goggles with vents taped over.
    Latex Gloves (1 Box)
    Leather Gloves 1 Pair
    Full cover Hooded Tyvek suit. Rubber Band or Tape the Wrists and Ankles
    Talcum Powder (coat yourself TOTALLY with talcum powder prior to every grinding Session. USE A LOT)
    Equipment
    Prybars, Hammers, chisels, Putty Knives
    Flat tipped shovel to remove foam, Old Carpenters Saw (The Old Fox Hole Army Surplus Shovels work well)
    Circular Saw
    Sawzall
    Dremel Tool
    Router
    Drill
    Random Orbit Sander
    Rasps, Files
    4 1/2" Grinder with Backup Pad and 24 grit resin coated sanding discs
    Masking Tape
    Shop Vac for dust control or Dust Collector if you're fortunate enough to have one. It's good to create a Plastic Tent over the boat to contain the dust. There WILL be a LOT of it....A LOT!!!!
    Product
    3 sheets 3/4" Arauco Ext. Grade Plywood
    1-2 sheets of 1/2" for Seats
    1 sheet for Side Panels
    15 Gallons 435 Polyester Resin
    10 qts Cabosil
    1 lbs 1/4" chopped strand fibers
    25 yds 1.5 oz CSM
    15 yds 1708 Biaxial Cloth
    dozen 1 qt plastic mixing buckets
    1/2" x 5" Fiberglass "Bubble" roller
    Dozen Stir Sticks
    2 dozen Short nap 6" nylon roller covers and trays
    2 dozen 3" Chip Brushes
Ninjafied
wow that is quite a list what have i gotten myself into?
thanks very much
