1984 Skeeter Champ 16' Restore
JDA1975
Re: 1984 Skeeter Champ 16' Restore
you could complain and it would be justified...because it is a chevy!
fmjnax
I hear ya Judge. I've been a Dodge boy for the last 15 years, with the exception of 6 month stint with a Ford, so it is a change for me. I can rip a Dodge down and build it back up no sweat, but this is uncharted territory for me! But, the price was right and it's really in immaculate condition. It's an '07, had just under 50k miles, and was a 1-owner vehicle. For $15k in this condition, it was the perfect truck. I looked at a Dodge that was also an '07, but had 80k on it and wasn't in near as good condition (and it was $3k more!). It looks like I'll be a Chebby guy for at least a few years now. ;)
fmjnax
I know my project doesn't appeal to many folks out there, but I still feel obliged to at least keep the thread updated. I haven't taken any new pictures (mainly because I know they kind of fall on blind eyes out there), but I have made some progress. This pictures-less update is kind of long, but at least I can say I made an update.
Memorial Day has now passed and, just as I thought, I didn't make it back out on the lake. Funds are rolling back in and I've started to work on it again, though.
When I left the boat to go buy the truck, I was still finishing up the casting deck and the inside of the hull, so that is where I will pick up.
I finished fabricating the new casting deck. It is tabbed and glassed to the hull. I still need to grind down the rough edges and finish fabricating the lid, but it's more-or-less complete.
I also finished glassing in the stern foam boxes. At the same time, I cut out my bilge and installed the new drain tube and reinstalled the livewell pump.
I had a problem with the new drain tube that is worth mentioning. When I drilled out the hole, I drilled it about 1/8"-1/4" off-center (big OOPS!). The result was a drain tube that wouldn't seal up tight against the outer transom skin. No matter how much I flanged it, it wasn't a flush fit. I tried 2 different drain tubes and also attempted to make my own from a piece of aluminum pipe. It simply wasn't going to work.
My options at this point were: (1) Fill the hole, fill the outer transom skin, re-glass the inner transom skin, and start from scratch. (2) Attempt a home-brewed solution.
I ended up taking option number 2 (I like to use my head). I went to Lowes to the plumbing (PVC) department. I picked up a coupling, a couple of bushings, and a couple of screw plugs. Back home, I drilled out the thru-hull hole with a 1-1/4" bit and used a rasp to file out just a smidge more. I coated the hole and the PVC coupling with 3M 5200 and wedged/hammered it in. It was about 1/8" too short to be an exact fit but it wedged in there perfectly. Next, I cemented the bushings into the coupling; one on the inside and one on the outside. I hammered them into the coupling so that the flange of the bushing was flush with the transom skin; both inside and out (and I should note that on the inside, where the coupling fell about 1/8" short, I "filled" this gap with the 5200). With the bushings installed into the coupling and the cement dried, I screwed in the plugs and sealed around the bushing flanges on both sides with some more 5200. 2 days later, I removed the screw plugs and did an inspection. PERFECT!
While the solution isn't ideal, it should work perfectly fine. It actually looks pretty good, too (I was thinking it was going to look entirely out of place). I chose to do a bushing on both the inside and the outside for some added peace of mind. My "plug" will actually be 2 screw caps. I'll screw one on the inside of the bilge in addition to the one on the outside. My thought with that was that IF, by any chance, the outer plug works itself out, the inner plug will be the backup. It's not going to be as easy as a traditional plug and I'll have to keep a wrench in the boat for tightening/loosening the screw plugs, but it will work.
Finally, if I wasn't sure how it was going to work up until now, after the rains we had overnight I do know now! I forgot to pull the screw plugs out and when I stepped outside this morning, the hull was full of water! There wasn't as much as a drip coming from drain area. I removed the plugs and the water drained out as I would expect.
With the drain plug dilemma over, I can move on to other things.
The casting deck was done. The deck and foam boxes were done. The livewell pump and drain tube was in.
I cleaned up the top cap and shot another 2 coats of paint on it. I left it cure for a week or so (actually, this was done BEFORE I finished the hull and did the drain tube). After the top cap had cured, I pre-ran my new wire harness.
My prop has been at the machine shop for a few months. Some friends invited us to go camping with them for Memorial Day, which just happened to be down the road from the shop. I got lucky that he came back from vacation and was open the next day so I stopped by and finally picked up my prop. It looks better than new and should give me a little more "oomph" now that the blades are repaired and balanced.
We got back home on Monday and later that night I took the top cap off of its stands, moved it in to the garage, and winched it up. I did a final cleaning of the hull and moved it underneath the suspended top cap. I lowered the top cap onto the hull and (surprisingly!) it fit like a glove. I put in a few rivets to keep it in place and I pulled it out to the driveway.
I have to do some painting touch-ups here and there (especially where I stupidly dripped resin!) and then wetsand, polish, and wax it up. Once done, I will begin to lay down the new carpet, run the wiring, install the hardware, and finally put the motor back on. I'm guessing about 2 more weeks and it will be complete.
fmjnax
Still no pictures (I'll take some of the final product when it's done, just to close up the thread here) but it's about done. Top cap is back on and secured. The bulk of the wiring is ran. The carpet is laid and the hatch lids are carpeted. The new deck hatch is done. All of the thru-hulls are installed. The bilge and livewell pumps are back in.This weekend I will be installing hardware and possibly hanging the motor back on. Another week and I'll be done.
kwik_uk
:eek::eek::eek: SUPER DROOOOOL :eek:
I want one :)
JDA1975
bleh! I want pictures, I still follow your skeeter, even if I dont post much anymore, just super busy lately
Woodonglass
We're still here!!! Nice fix on the drain tube!!!
fmjnax
Motor is hung and the trim pump installed. The helm and steering cables are connected. I had a little problem with my control box wiring that took 3 days of frustration to figure out, but last night I finally test-fired the motor on the muffs. She's alive and kicking!!!! We're wrapping up everything this weekend! I still have to carpet the bilge hatch (doing that last, while I'm working in the bilge area). I still have to install the cleats and lights. I still have to hook up the livewell hoses. Still have to install the trolling motor. Still have to make all of my wiring connections under the console. I also have a little bit of paint touch-up work to do, but nothing major.
The splash is going to be a little while away, though. I have a surgery next Wednesday, and I have to send off paperwork to register the boat, and then on July 1st we're moving in to our new lake house! 3,300 square feet of prime waterfront living! 1.5 acre lot, private two-stall covered boat house with lift, and private concrete boat ramp right next to my boat house. The splash will be me taking the boat from the ramp to the boat house. :)
kwik_uk
My experience so far with milky sections is somewhere, somehow that area got wet with either water or sweat...have had it happen a couple of times, but in small areas...some may have to be ground out and redone, others will live as such...
If the cloth somehow got wet, and was not completely dry, this could happen also...
The other time I have had white milky looking spots, is when I try to bust bubbles too aggresively and actually lift the glass from the surface, if it has started to gel...it wont stick back properly...if it is still wet, I can usually add some more resin and dab it away with the brush...
Had this exact issue myself when glassing in my new floor. One corner of the ply had got wet, I thought it had dried out. Obviously not. Only a small 6" x 3" section in a non-stressed area, so I'm not too fussed. Resin did harden as intended, just wasn't totally transparent.
fmjnax
That had to have been what it was. I had the plywood lying on the garage floor to try and keep it flat. It very well could have been that that particular piece was the piece on the bottom and the concrete slab had sweated a bit to put some moisture on the top layer. None of the wood was wet when I cut it, but there could have been just enough to cause the problem. Ultimately though, it all turned out fine after a little bit of redo work.
I'll be uploading some pictures either tonight or tomorrow. I got my tags/stickers today so the boat is officially legal in the state of Texas. I've got just a little bit of wiring and minor hardware to install so we're going to try to finish it tonight and take her out for the splash tomorrow!!! I've got my fingers crossed!!!
fmjnax
Here we go folks! The SPLASH has occurred! The entire family spent last night and this morning putting the finishing touches up on the boat and making sure everything was accounted for. We finished everything up shortly after noon, loaded up 12 gallons of fuel, a cooler full of drinks, sandwiches, and snacks (we were very optimistic!), the tube for the kids, all of the safety gear, and headed to the marina down the road. Here are the pictures before pulling out of the driveway.
fmjnax
The marina is exactly a mile down the road, so we didn't have too far to travel. The mile was a clean and easy drive, though. Nothing bouncing around and no problems. We pulled up to the marina with perfect weather; overcast skies, cooler than normal temperature, south wind at 5mph, and water as calm as glass. The marina was also less busy than usual, which meant that I had time to sit on the trailer and in the water to do some on-water inspection. Absolutely no leaks and it floated nice and level. The motor cranked right up on the first try so I pulled off and parked while I waited for the family.
As I was parking, the motor died and I couldn't get it fired back up. The marina attendant threw me a rope and I tied up while I tried to figure it out. Stupid me, I forgot that my motor likes to warm up tilted with the prop just barely under water. I sat and let it fast-idle for a few minutes while the family loaded up into the boat and away we went.
We left the safety of the marina cove, checking the bilge area every few seconds it seemed. Everything was bone dry. The motor was purring great and the boat was tracking true. Outside of the wake zone, I punched it and got up on plane. We cruised around for about an hour at all different speeds and maneuvering. Everything was great. I'll even go out on a limb and say that it rode a heck of a lot smoother that it did before the restore.
Confident that everything was good, we headed back to the truck to get the tube and the cooler. We headed out and did some tubing, some swimming, and some more cruising around the lake. The bilge remained absolutely bone dry the entire time. An absolute success, and we will be heading back out tomorrow!
I want to take the opportunity to send out some special thanks to Woodonglass, JDA1975, GT1M, and everyone else that has helped me throughout this process. When I started, I didn't know what the heck I was doing or if I was ever going to get it finished. I still have a few minor clean-up tasks to do (cleaning the carpet edges, namely), but I am considering this restore complete. I'm glad I had the iBoats forums to help me through the ordeal!
Here are the pictures my wife took with her "CamWow" app thingy. Yes, my sons hair really is green/blue (it's semi-permanent color just for summer time). You can also finally catch a glimpse of me at the helm. :) Sorry for the sideways pictures.
JDA1975
Nice job man, thanks for the pictures...Glad to see at least one of us got the boat splashed this year! I have just been so busy on others projects that the skeeter has been put on an indefinite back burner, but rest assured I will get it done!
fmjnax
Thanks Judge. You'll get it done! I HAD to get it done. I'm having surgery next week and then after recovery, I have to pack up my house. For most people, living a mile from the lake is nice but... we're closing on a house ON THE LAKE! My own private boat ramp, 2-stall boat house, 1 acre lot, out in the country. I was not going to be moving a half-finished boat and I knew there wouldn't be any time after the surgery. The past couple of weeks I have been putting in 8+ hours a day on the boat; staying up until 2 and 3 AM working in the garage (and having to be to work by 8 the next morning).
fmjnax
Here's some before-and-after pictures. HUGE difference!
ezmobee
Looks great! Congrats on the splash. I'm insanely jealous of your new property!
Woodonglass
fmjnax, Great Splash!!! Job well done! Get past the surgery and back on the water soon. Enjoy the fruits of your labor.
Decker83
Great to hear you splashed. The boat looks excellent and the trailer does too. You can really tell that all your hard work paid off.
The seats look great too. Glad to hear you and your family had a good time with the new boat.
Thanks for sharing with all of us here on i-boats.
