1984 Volvo Penta Outboard leaking.
PiratePast40
Re: 1984 Volvo Penta Outboard leaking.
With the amount of water coming in, it's also possible that the exhaust pipe is cracked, loose at the flange, or the o-ring is missing. Here's a picture from inside the boat with the engine removed: P1010055.JPG
It's thru bolted from the outside with 4 bolts. Here's a picture of one of the bolt heads from the outside of the boat. The rest are behind the exhaust bellows:P1010151.JPG
Getting behind the engine to check is a bear - here's a picture with the engine in place: P1010142.JPG
Here's what dryrot in the transom hole area looks like. You won't be able to determine the extent of it until you remove the transom shield: P1010066.JPG
Robbie5374
its not the ext. i put a hose in the engine bay and filled it up. wanter leaked from the bottom of the transom
