coleman kayak1
- Joined
- Aug 8, 2005
- 260
Recent motor issues lead us to decide to end the season semi-early and do this project.
For about 3 years now a couple spots on the 'toon deck have been getting soft. At first it was no big deal but after a couple seasons it got to be pretty bad, especially in one spot right behind the helm. It was so bad we had to patch it just to get through this season without a potential (ly wet) catastrophe.
We decided to just replace the entire deck. We found many more soft spots and patching would be a temporary fix at best. Material was pretty much obvious, factory spec 3/4" marine grade plywood. Floor covering we had some debate over. Problem is carpeting and vinyl come in 6' wide widths, which is practically useless for a boat using 4 4x8 sheets of decking. They did sell pontoon versions which were 8' wide but at the price they should be gold plated (25 a foot for vinyl). We ended up deciding on cabela's Tuff Skid Coating. It seems like it should provide a durable nonskid coating which is what we are shooting for. In addition, even though its a lot, its pretty cheap relatively speaking.
While we're at it I'm planning to replace the lights with LED models. The incandescent ones would corrode and quit working at least once a season and they haven't worked in 10 years or so.
To accompany the new lights we're redoing all the accessory wiring. The way the boat has been wired is just basically running a wire clear to the back for everything. I think there are 4 positive and 3 negative connections, not including the motor. I plan on installing a nice switch panel and running just one primary wire up to the helm.
Docking lights and a new seat are just icing on the cake.
Grandpa and I pulled off the top yesterday, wasn't too bad its not any heavier than an aluminum truck canopy I don't think, still was good having two people, here is the boat with the top removed
Here is a picture of the patch we did
And here is a picture of why (you can't really see it but the unfaded part of the floor used to be inside that aluminum piece) :shock:
Got started early this morning on it. Took all the sides off. Had to take this picture, wouldn't the boat be kinda cool like this?
