Re: 05-10-2012 - re-tab in stringers and transom
Thanks for the comments woodonglass. Greatly appreciated! I plan to put a couple of layers of 450GSM CSM on the top of the deck. I was going to wax it but the guy at the fiberglass place suggested I flowcoat it before putting the carpet down? I hadn't decided on whether I would be gluing it down now I sorta figured I would though.....
True but carpet gets wet and holds moisture. I think it would just be a better substrate. Heck if you're gunna glue the carpet down, you really only need to lay a couple layers of CSM and wax the last layer for waterproofing then scuff sand just before applying the glue for the carpet No Paint of Gelcoat or anything is required.
