1986 70hp johnson overcharging
sickboy
I just finished rebuilding my dash in my bass boat with all new digital gauges. When I fired it up on the muffs for the first te tonight, I was watching the voltage gauge.
Without the motor running it was reading 12.4
Started the motor and I was @ 13.4 slowly climbing without revving the motor.
I saw it hit 14.4 and still climbing.
Around 15 volts, all the digital gauges started glitching so I shut it down. I restarted the motor and the exact same readings and rate of climb happened again.
It's safe to assume the glitch was because at 15 vlts the gauges were trying to protect themselves.
My question is, what the hell is going on? I've been reading the service manual and nothing talks about overcharge scenarios, only under charge.
boobie
Re: 1986 70hp johnson overcharging
The 15-17 volts is normal on that motor. It doesn't have a voltage regulator. Just a rectifier. Your gauges may be designed for a motor with a regulator.
sickboy
Can a voltage regulator be added easily?
boobie
Check other posts on here. I know they're out there. OMC used to have one, part # 173640.
sickboy
I did see a thread discussing that p/n but that part is for a 4 & 6 cylinder. It won't matter going on a 3?
Bosunsmate
Interestng boat panel, thatd keep my eyes off where i was actually driving.
Looks like an f16 setup
A voltage regulator can always be added into a circuit, my car has one, radioshack or the likes should be able to get you a good 14v one
J JACKSON
i would check the manufacture but most gauges will work at that voltage i would double check your wiring especially the grounds
sickboy
The wiring is solid. I just redid everything. I ran a new 8 gauge pos and neg feed from the battery up to the console where they go into terminal strips. The pos goes to the master switch then into the terminal strip.
The manufacture says the gauge reads 0-15 volts. It's right at 15 when all the gauges start franking out. So somehow I need to limit it to under 15 volts.
Faztbullet
CDI has a direct replacment with built in regulator.
sickboy
Thanks I will look into that. Is it a replacement rectifier that has a voltage regulator built in? I'm just a bit confused to what the replacement part would be replacing if my motor dosnt have a regulator to begin with.
boobie
I'd give the one from CDI a try.
sickboy
Definatly, found it for $70 online. I'll post back with a update. But I figure if this dosnt fix all the problems 100% I can add a small regulator at the panel to protect the guages.
sickboy
Different question:
When running the motor the other day with the muffs on, after a few minutes the water stream just quit. The water pump has 2 seasons on it. Is it common for a pump to just quit? I thought it may be a thermostat but my motor is slightly different than the schematic in the book. The book shows a thermostat above a pressure relief valve both under the same cover, however I have a smaller cover and it only has a pressure relief valve under it.
Bosunsmate
Different question:
no.
sickboy
I also noticed some water coming out above the lower unit and also at the top of the mid section? I didn't see anything in the service manual about servicing up in there. What hell is going on? I will try to take a video tomorrow.
sickboy
This is the pressure relief valve with no place for a thermostat. Not really sure what the. Purpose of this part is for. The manual shows this and a thermostat but it's not the case.
sickboy
Read thru the message boards and someone said to poke the telltail nozzle with something thin. Fixed the problem, just was clogged a bit
boobie
In pic # 1, that is the thermostat. It's got a vernatherm inside of it. Your manual is wrong.
