1986 Ebbtide Dynatrak 150 Restoration
Status
Not open for further replies.
jbcurt00
Re: 1986 Ebbtide Dynatrak 150 Restoration
Foam is primarily the required FLOTATION for your boat, don't leave the dry dock w/out it.
So I see U have removed the foam boxes and I am assuming you are going to fill up those holes on the deck with expanding foam.... Is this to make the hull and deck more solid basically?
These are added benefits, but flotation in the event of an emergency, is the primary function.
jfas
Looking nice! I have been waiting for your next update.
So I see U have removed the foam boxes and I am assuming you are going to fill up those holes on the deck with expanding foam..?
I also seen frisco boater do that. Is this to make the hull and deck more solid basically?
Hey Dro,
Glad to know that you're following along. I ended up removing every piece of wood from the boat including the foam boxes in the aft corners. I think the next update will show how I re-fabricated those. As far as the holes in the deck, I used a 2" hole saw about every 18 inches so that I could pour and fill the voids below the deck with expandable foam. As jbcurt mentioned, I did this for a couple reasons. First and foremost is additional flotation in the event of a sinking or swamped boat. Secondly was to fill any voids and creating a more solid structure. As of right now I have about 1500 pounds of additional flotation that I have added to the hull and every nook and cranny. There aren't too many other places I can fill. The boat weighs about that, so in theory in the event that the boat swamps it should remain afloat.
Jfas
jfas
As I mentioned in my last post, I have been putting a lot of hours into the boat in order to make sure it's ready for this summers boating season. With that said, I already have another update.
When I left off, the deck was complete and filleted in.
Here's a shot of how I plan on mounting the bilge pump. Pretty simple, just a piece of 3/4" ply coated in resin and filleted in with PB. I will eventually cover this ply with 2 layers of CSM as well.
Next I cut a bunch of 1708 and did a 6" tab all the way around the deck.
I found this piece of masking tape in a cranny in the top cap. Apparently this boat was repaired at the factory once before. I made sure to add my signature as well. :)
Once the tabbing cured, I jumped right into glassing the deck in. First layer of CSM going down. This stuff uses an absolute ton of resin. I think one layer was about a gallon and a half.
An iboats staple in the forums. 3M respirator and safety glasses. Can't tell you guys how many times both of these have saved me during this project.
My updates are lagging slightly behind my progress. So, this weekend I have another huge list. I plan on tackling the rub rail attachment points, the electrical system, the steering system, and some minor tweaks to the glass work on the cap. Early next week is carpet, and remounting the cap.
Cheers!
Jfas
Woodonglass
Yup and a Head Bandanna comes in handy to keep sweat droplets from getting in the eyes helps too!!!!
bvetter
Nice progress!
jfas
Well, another weekend another couple of days of progress. I'm getting really close now. The devil is in the details for sure.
When I left off, the floor was all glasses in and waiting to cure.
Here's a shot of the flotation boxes that I refabbed. Before they were just poured foam that was covered with one layer of CSM. They looked like crap and didn't really add any structural value. I decided to make the sides from 1/2" ply and the top from 1/4".
Once I had the hull locked down, I created ribs and PB'd them in. It's crazy how much strength this added to the sides of the hull.
Tabbing in the flotation boxes.
Filling the flotation boxes with expandable foam. I filled them most of the way up and then closed the top and filled them the rest of the way.
My braces removed after the PB and tabbing cured.
After a long weekend. A tall cold one.
More progress on the way!
JFas
89 resorter
Very nice work JFas! I think I just figured out from your last pic how to speed up my rebuild project......wait till AFTER the work is done before cracking open the tall cold one.
Keep up the good work!
jfas
Hey everyone,
resorter, I may have had a few that day.
Anyways, still pushing really hard to get everything done as quickly as possible. So, here's another update!
Most of the major fabrication is now complete and it feels great. I'm spending time on the electrical system, some small repairs on the top cap, the interior, plumbing, and etc.
So, here's we I left off. the deck was complete and glassed in, the flotation boxes were mostly complete and the side ribs were tabbed in.
Here's a shot of the flotation boxes complete with glass and flotation foam most of the way to the top.
This next shot does a great job of showing how I fabricated the side panels to give the interior a nice finished look. A couple of other benefits are the huge amount of strength this created to the sides of the hull as well as a nice little hiding spot for a couple more cubic feet of foam. Also notice the natural light, yes that is the garage door open for the first time since I started the project.
The first layer of tabbing going down for the sides.
The CSM going down.
I picked up some bilgekoat and painted the aft section of the boat. Some of this may end up carpeted, but I haven't decided yet. I just painted the whole area for now. Also note that the flotation boxes are complete, filled with foam and capped.
If anyone was wondering how much the foam from US Composites expands, here's a great example. I would say there was about a 1/2" of liquid left in the bottom of my mixing bucket and it expanded this much. Pretty nuts!
Well, that's it for another day of updates. You guys keep reading and I'll keep posting.
JFas
glnbnz
Wow your project is really coming along nicely. Thanks for the updates, I will keep reading!
SAT_Bob
Excellent work! Keep it up. I'll be following along.
jfas
Thanks guys for following along, I hope that maybe I might be able to help someone else.
I have to apologize, I have been so focused on getting the black bomber wrapped up that I have been neglecting to take photos. I do have a few to share though.
When I left off last time I had the rear of the hull deck painted and ready for carpet and finishing touches.
Here's a shot of the carpet laid down. The dark spots are just fuzz balls from cutting and rolling the carpet. I got the carpet from Amazon and it turned out really nice. It's just a 20oz rubber backed marine outdoor carpet. I picked up some outdoor glue from Menards, troweled it on and then rolled it all out flat. The carpet really conformed well and laid down nicely.
After getting the carpet all laid in and the 24 hour cure time, I started to tackle the wiring. I have always been good with wiring and really enjoy it. I may have gone a bit overboard. Here's a shot of the bilge.
Here's a shot of my battery setup with boxes. Notice that all of the wiring is contained inside of wire loom. Keeps everything nice and tidy.
Just a shot of the circuit breaker for my trolling motor and a ground buss bar for the ground circuit in the aft of the boat. Having a buss bar really eliminates the need for all of those wires being connected directly to the battery.
I know it's hard to tell from this picture, but this is the area in the boat that the wiring converges on the helm. Looks like spaghetti junction right now.
So, that's basically where I'm at now. On the agenda for this weekend is to finish terminating all of the wiring, finish the plumbing installation, repair the cap in the rear that I had to cut to remove it, and hopefully fully re-install the cap.
I did run into a small snag. I got a little over zealous with the wiring and decided at the last minute to pull wire for speakers. Well, I didn't take the time to measure very well before installing the port side speaker and ran into some clearance issues with the side bulkheads of the hull. I was pretty annoyed at first, but I have come up with a work around. I plan on just cutting a small part of the ply out to relieve for this speaker. I don't think it will have any impact on the structure, since there was nothing there before. Anyways, still lots to do.
JFas
jfas
Big news! The cap is installed on the boat. I'll get to the pics in a minute, but I can honestly tell you that I really underestimated the amount of time that some of the details would take. The wiring, plumbing, little odds and ends, man they really add up.
Anyways, I do have some progress pics to share.
This is one of the things that I sort of forgot about. It ended up being about a 3 hour project. When I removed the cap, I really tried not to cut any of the cap or hull. The way it was installed and the amount of peanut butter they used near the transom made it all but impossible to remove without cutting out the motor well.
Here's a shot of the 2 pieces fit back together and ready for glass.
Here's a shot of everything glassed back together before any sanding.
Picked these beauties up from Amazon for $49 bucks. They sound awesome too.
The cap fitted. sealed, and screwed down for the last time!
About mid-way through the wiring on the helm. Almost everything is hooked up and working, now to just get all of the wires routed and cleaned up a bit.
I can see the light at the end of the tunnel. I plan on hanging the motor this week, installing the shift cables, steering cable, and controls. I also have to finish the wiring, test run the engine, and then it's off for a tune-up.
JFas
glnbnz
Yeah the odds and ends can be just as challenging. Keep up the good work you'll be boating in no time :)
Heff610
This post is truly inspirational as I need to do the exact same thing, I’m very new to every thing on this and thank god I found this post as it’s to the point to what I need to do. Only thing I need to know is the name of the materials that was used so I can start purchasing and cost of it all of this full restoration any help would be appreciated as I know not much at all
Status
