1986 Mercury 9.8 110 outboard
Kissdude
I was wondering if someone could help me please. I have a 1986, 110, 9.8 mercury outboard. It’s been sitting a very long time but I have spark, carburetor has been soaked in gunk and completely cleaned but I still have no wet spark plugs. Plugs have been replaced as well. Any help here would be appreciated.
86 should be a 9.9/15, where the prior 7.5/9.8 series ended in 1985
Did you do a compression test? Issues with the reed valves?
Did you set the float correctly?
Did you go thru the fuel pump?
Kissdude
I’m not sure why they say the reeds are behind the carb on this one, I believe they are under the flywheel. Upon looking they look like not sitting flat but trying to find the manual to look this up.
Kissdude
I’m having troubles locating my manual. It’s a 9.8 110 Mercury, model number. 7151133 any help would be appreciated
airshot
If compression is good, then do a rebuild on the carb with a factory rebuild kit as it will give you all the specs for setting it up. Just cleaning rarely works in my experience, you need those new seats and gaskets. Also a thorough take down to clean all those tiny passages. If compression is good, you have spark and fuel, it will run.
Kissdude
I took the carb apart, soaked it and then cleaned it all up, motor doesn’t even try to start. I have a bowl full of fuel, compression and spark, plugs are still dry tho so no idea. Was thinking maybe the reeds but like I said I don’t see them behind the carb.
Kissdude
I have tried spraying premix into the carb along with ether, I know that’s bad but nothing happens at all. I’ve also been using an online spark tester and I do get spark.
jimmbo
A spark tester like this? Don't waste your time or money on ones that are in a Bulb
Don't spray Ether into a 2 Stroke, not a good idea as it ignites by compression, and there is Compression in the Crankcase too. It also can wash away Oil, very critical for the Bearings
Maybe try a few drops of Premix into the Sparkplug holes, and see if it lights
Kissdude
jimmbo
A tester like the one I post a pic of, is adjustable, and puts the Ignition System to the Test. They are available on Amazon, and Evil Bay. A very large Gap is required because not much Voltage is required to jump a 0.030" Gap at Atmospheric Pressure, in the Combustion Chamber at much higher Pressure, a lot more Voltage needed. That 0.030" Gap on the Plug is now closer to a 5/16" Gap at Atmospheric Pressure.
Electricity is a creature with a One Track Mind, connect to Ground. And it doesn't care how it gets to do so, and will always pick the Easiest Path, so any weakness in the Wire Insulation, cracks in the Coil Housings or the Plug Ceramic Insulator, will offer a lesser Resistance than the Plug Gap
There are Reed Stops(part #12 on the Parts List) above the Reeds. They limit the Travel of the Reed, and they are Curved away from the Block, so maybe you are seeing the Stops.
Kissdude
That makes a lot of sense, thank you. I must be seeing the stops and the reeds are probably good then. I haven't learned much about reeds yet nut probably should. I forgot that I ordered new coils last fall along with a tester like the one you showed here and maybe try the new coils to see if I can get better spark.
Thanks again
airshot
If the plugs are dry, the carb is not letting fuel in, you probably have a blockage that you missed, or compression is low enough to not draw the fuel in.
Kissdude
So I went out and tried this morning and pulled her a few times and no start but now, the pull start came apart and feels like I have no compression like I broke something? there is little resistance when I turn the shaft and propeller moves when I do. The pistons still go up and down. Any idea of what might have happened?
jimmbo
The Recoil may have failed. When you pull the Cord, does the Flywheel turn? Or does the Cord just pull out, and then goes back in?
Have you ever done a Compression Test on this motor?
If yes, what were the Numbers?
If no, do it and post the Numbers
