1986 Weldcraft Aluminum Boat W/ Turbojet
cecilh0544
I have the boat described in the title. The power head is installed as an inboard. The motor is a 90 hp cross flow - 2 stroke - Evinrude. I am having continuous issues with the fuel flow and most of the isses appear to relate to the VRO unit. I spend more time with the fuel pump than I do enjoying the boat.
Can anyone give me some advice here as it appears an electirc fule pump replacment is not an acceptable modification? Thanks very much for the help.
tashasdaddy
Re: 1986 Weldcraft Aluminum Boat W/ Turbojet
Vro Replacement Fuel Pump Kit "no Oil"
(for Using Oil/gas Pre-mix In Fuel Tank)
#5007422 it is in the $300 range.
$100 range
Part Number: 0385784
Description: FUEL PUMP AY
Pack 0395712,0398385,0433390,0438559Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts:
