1987 bayliner capri w/ omc 3.0 and cobra out
wht89gt
Hi all so im having a problem with my boat i just bought. Im getting a knock low on the block it goes along through the rpm range i was curious if it was the u joints or gimbal bearing so i pulled the out drive off and fired it up for a min still get the knock its on the starter side toward the back of the motor. Im guessing its a rod when in the water im loosing out of the hole power occasionally and the motor diesels almost every time i turn it off i havent done a compression test but im figuring im due for a rebuild. So not a whole lot of boat stores around here i bought new rings and crank bearings off ebay but cannot find rod bearings anywhere can i buy them at an autoparts store advance autoparts is right down the road. Also have a seloc manual sorry but its pretty much useless no specs at all for a rebuild but do i leave the mounts on the block and mark the bolts to the frame or do i unbolt them from the block and leave the mounts in place? Never had to realign a boat motor but ive rebuilt a handfull of auto motors just dont want to mess up the alignment and not be able to get her back on the water quickly. Thanks for any help guys i really do appreciate it great forum tons of knoledge and definetly should have listened to the advise on the seloc manual!
Gary H NC
Re: 1987 bayliner capri w/ omc 3.0 and cobra out
Pull the lag bolts out of the stringers and leave the motor mounts attached to the block.
You will still need an alignment tool to put the drive back on.
Also you need the factory manual for all the specs ans step by step engine rebuild info along with all the shift cable adjustments,ect....
Napa may be able to match up the bearings once you get the old ones out.
Mark everything,take pictures too...it can really help.
here are a couple of the correct manuals,
http://cgi.ebay.com/ebaymotors/1987..._trksidZp1638Q2em118Q2el1247#ebayphotohosting
http://cgi.ebay.com/ebaymotors/1987...1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
