fallautumn2
Thread starter- Joined
- Dec 4, 2009
- 24
Hi guys I just finished a rebuild of the fuel pump and carburettors, and found that at least one of the wires attached to the right hand side of the switchbox has the insulation falling off it, when you touched it even more just fell away - the wire is exposed and green showing corrosion. For now I have covered it in electrical tape. The wire ( a cream white colour) I assume is coming from either the stator or the trigger.
My question is if this is so, can the wires to the stator and trigger be replaced without replacing the stator or trigger??. (eg do they just clip or screw into these components??).
Thanks in advance. Kevin.
