jmcardamone
Thread starter- Joined
- Aug 6, 2010
- 19
OK guys im back..
The last time i was on here with my motor i got my problem resolved by repairing a ground wire on my starboard CD pack. Since then the Pack toasted and i had to replace the pack. Motor runs, goes on plane and runs the boat at about 34 MPH (16.5 Fish n ski, 13x15 Alum prop). While she runs Great at WOT once shes up on plane, I have some other issues that make the whole experience less than pleasureable...
Starting: Starting Almost ALLWAYS requires my use of the primer and the Idler (the netural throttle lever) to be at 25/50 percent of its max travel range. I have to start it, let it run at that throttle until it smooths out and then i can drop it down.. Until it warms up a bit the idle will die sometimes. IM OK with that, but there are times where She just dosent want to start, and i shouldnt have to race the **** out of the motor to get it to start..
Gear Engagement: Its a 50/50 crapshoot wether she will die going in gear or not.. I brought my idle up a bit, to around 1100 and she drops down to 700 when in gear, however im not so sure if these measurements are correct as my tach is intermittent (which i will bring up later)
Holeshot: When its just me, She climbs out of hole Ok, but for a small pitched prop i would imagine she would jump out faster.. I have tired different Tilt angles and such but its still Laggy. a 110 HP motor shouldnt struggle this much. Now last night i had 3 guys + myself in the boat and we couldnt get the boat the plane out on its own without having someone sit up in the bow until it came up on plane. I may have been a bit overloaded, i understand that, but this prop is pitched low enough that it should be able to handle it in my opinion..
Charging: Motor does not charge battery. Same Battery voltage present at the Red wire off of my rectifier In pre start/Post start State. This voltage is also the same at the Battery. I have 21 volts AC across my 2 yellow stator wires. I have an intermittent tach pulse.. The charging and the tach pulse is generated by the Rectifier (at least my wiring digram shows my tach pulse grey wire leaving the rectifier). IM figuring my recitfier is dead. I cant test this futher until my DVA Adapter comes in next week (at least according to my test procedures)
Throttle Lever/Direction: I beleive i may need a lync in sync. She Has a Lot of travel in the forward direction but a short distance for reverse, and she tends to start ramping up the speed a bit as she starts to go into gear.
Timing adjustment Screw: For some reason the linkage assembly never really gets all the way back to where the screw contacts the plate when its in netural. Ive suspected theres something screwy with the timing and im wondering what would cause that screw to not want to go all the way back.
Things im thinking....
1. Anti - Siphon vavle. The one on the boat is original, 1987. The valve makes noise when the ball is trying to fill. Im wondering if its obstructing the fuel flow starving the motor.
2. Port side Stator - I took the flywheel off recently to change my starter gear and i noticed my stator on the port side was "sticky". Its an expoxy coated unit and i read someone that means death or immient death.. Could it be that the stator is not giving the full 150 volt pulse to the port side CD pack and that might be underfiring the Pulgs? Ive done the spark test but i get mixed results (ie Monday i get bright blue spark at 3/8", wednesday, i get slightly orange). Again, i cant test this voltage until the DVA meter adapter comes in from USA tool wharehouse, a business i will never deal with again..2 weeks and its still not shipped.
3. fuel Pump.. Maybee? When the boat is under heavy load she seems starved for something..
Just to note the list of new parts in the motor..
All Fuel lines Internal/external
replaced trigger with Used trigger thats good
New starboard CD pack
New Plugs (champions)
New wires (them seirra blue jobbers, 6 inch)
Carbs Rebult and Squeaky CLean
New fuel filter
I am ready and willing to do any Test you wish,a nd i will even provide Video if you feel you want to see what im doing. Im not giving up on her yet as i am this close..
OH BTW,, COmpression is 104,105,107,103 across all four... Leakdown test passed as well. Held thier Compression for a few hours..
I appreciate any suggestions. and i will Respond with the Overall fix(es) as they come about..
THANKS FOR LOOKING!
New fuel filter
THANKS FOR LOOKING!
