oldboat1
- Joined
- Apr 3, 2002
- 9,612
14/15mm spark is good. What was it that stopped working? (i.e., could be a bad plug wire or bad wire connection.)Yes I measured spark. I got out to 14mm or 15mm before it stopped working.
Both carbs have been taken off and completely apart and cleaned. Also I swapped the top carb with the bottom carb and the problem stayed in the same place so that leads me to believe it's not carb related.
