Watermann
- Joined
- Jan 12, 2013
- 13,857
The gluvit goes on the inside in the seams and especially the keel area so there's no mess to worry about too. I usually just run a drill wire wheel over them first to clean them up and wipe clean with some solvent like acetone.
I've not had an issue with the stripper on seal sealer I found it didn't do much of anything to the seam sealer on my SC boats, I noticed some of the over flow sealer would get soft but it wouldn't come off/out with the paint as what was sealing is sandwiched between the panels.
On the trailer, most of the boats weight is in the stern area with motor, battery and fuel. The bunks distribute that weight best so they should take 90% of the load rather than just a narrow keel strip. I use 2x6's for my bunks and have some info in my SS thread on how I made them up.
