1987 Sea Nymph SS175 Fish & Ski Rebuild - Tons of pics! *Paint COMPLETE*
carpedium
Re: 1985 Sea Nymph 175 Fish & Ski Rebuild - Tons of pics!
Well, went out and gave it a shot on my lunch break. I will post what I used for my mix ratios if there is any interest. At first I didn't think it was going to work because the mix was quite pretty non-homogeneous, e.g. lots of swirls and not mixing well. After I while I gave up and just shook the can. Shaking produced about 95% uniformity. 5% was still swirly. I thinned the whole mix at 15% with acetone, and also used hardener at the recommended ratio.
The first thing I sprayed was a scrap piece of AL that I had previously primed. I set the gun very lean, and had to fuss with it to get to the point where it was applying a realistic amount of paint to create a sheen. I was very surprised to see that it was going on very uniformly - and looked great with a very dark metallic gray that I was looking for.
Sitting out in the sun the scrap piece didn't take long to tack up. I had a more material in the gun so I decided to try a small swatch on the boat, since the primer had already dried and I had sanded a small area. It sprayed on the boat beautifully. I quickly sanded the transom, and sprayed that with what was left in my gun. So far so good. I will report on how it dries, but by the time i was done the AL piece was already losing its tack.
As always - some pics:
carpedium
carpedium
Last night got cut short by severe thunderstorms leading to hours of power loss. Bummer. I did manage to pre-mix the paint for this morning's coat (sans hardner). I also got the dash panels installed - I think they look great. Forgot to take pics, but will post some later.
This morning I wet-sanded, dried, tacked, and put the second coat on. I love the color, and the second coat went on way easier than the first.
Pics:
What looks like a run in this pic is actually epoxy from when I put the rivet in. I put it on too thick and did not sand it though. Can't really tell unless you're looking at this angle though. dammit.
The paint is really deceiving. From 5+ feet away it looks really dark unless the sun is hitting it directly. Then close up it looks really light. Really neat!
What do you guys think? Any tips for applying the final coat in terms of how thin or thick it is applied?
carpedium
- Get new control cables
- Install steering cable and helm
- Paint and install controls bracket and trolling motor outlet
- Paint and install trolling motor bracket
- Paint exterior of boat
- Install Seating
- Install dash panels
- Install windshield
- Paint/install gunwale boards in back for mounting downriggers to
- Create and install wire harness for non engine related electrical
- Install power TnT on Motor
- Install motor back on boat
- link/sync motor
- troubleshoot ignition issue
Woodonglass
I must say...Very impressive. I will be anxiously awaiting future reports on it's curing and usage durability once launched. You may have stumbled onto a very nice solution for some of the "Tinny" guys for painting their boats. I hope it all works out in the end for you, cuz right now it looks GREAT!!!!
carpedium
Thanks wood! The stuff seemed to cure like normal - I will do some long term updates with the paint as well.
Here is a pic of the dash panels installed:
And some of the second coat fully dry:
The third coat will go on in the morning - then I'll work on getting the seats, helm, and wiring taken care of. Along with my ongoing list:
- Install Seating
- link/sync motor
fleachili
The color and sheen of the paint is phenomenal!!!!
Well Done; anticipating the finale.....:cool:
lmuss53
Man that color is nice, kind of a Smokey Gray. I pictured it coming out a kind of shiny black, not at all what you got. I can't wait to see it from a little ways back out in the sun. If it holds up for you all Summer I'll be asking for the formula come November. :D
Davem3
wow, that is very nice. Lots of hard work about to pay off.
I learned i am going to be buying a air rivet gun ASAP.
OMG like many others here, i have always used a manual one, and Emanual is getting tired of the labor.
Although the Popeye arms are kinda impressive :facepalm:
if that paint hold up nicely, i am going to be looking for that formula as well................
fat fanny
Carpedium the color is perfect a great mix betwwen light and dark great work!
jigngrub
Heck yeah! Paint is fricken awesome! How long you been futzing around with one of those spray guns? I just bought one but haven't had a chance to use it yet.
What are the seating options going to be, and why no pedestal bases?
carpedium
Thanks guys! I will be keeping everyone posted on how it stands up to the elements this summer. Based on how this has dried/performed vs. the regular (non mixed) stuff I think it will be just as good.
carpedium
Thanks grub! This is the second or so project I have used it on - first thing was painting a motorcycle. Its actually really easy, just need to get the settings right. I can post a tutorial or a video on how I do it if anyone is interested!
For seating I am going to be using a 150 Qt cooler on the captains side, and i'll re-purpose the built-in livewell on the other side for added storage and seating. I'll post some pics of that tomorrow. The cooler will work out great for me because I need a large cooler on board for when I am fishing derbys/tourneys where a multiple 20+ lb fish box is very common.
carpedium
I got the last coat of paint on today, looks great I think!
Wet Sanded:
Also figured out what I was going to for wire routing:
You can get these from Lowes. I drilled 1- 1/4 or so holes in the gunnel-mounts and used these grommets to protect the harness I will make one for steering cable, the other for wiring.
Buckeyedude
Your paint job looks awesome! I really like the consoles too! Great work bud!
jigngrub
What kind of fishing are you doing in a "stand up" boat? Saltwater bottom fishing?
carpedium
Grub, it will be more clear when I post pics. I mainly fish lake Ontario trout and salmon. Not uncommon to have 25 to 30 lb class fish. There will be two seats mounted to the livewell, and the cooler will have a cushion for seating, just dual purpose.
Whenever fishing warmwater species, I usually stand up,anyway. The original layout from the factory had no pedestal seats, and it was near perfect for me.
jasoutside
Yup, me too. Course I'm not all that great of a fisherman but I think that has little to do with sitting down:rolleyes:
dozerII
Great looking rebuild, and really like the custom paint mix your working on.
Glen
drrambo1
:)Very nice job for sure... Boat looks great.. can't wait to see the final product..:):)
