irish24
- Joined
- Jun 29, 2009
- 49
A bolt below the water-line rotted the transom on my 16' 1987 fiberglass Starcraft....USCG labeled as a CSS-160B. I only mention this because I've not been able to locate or identify this boat online anywhere....any ideas? But anyways, I drilled a few holes @ 3/16" in diameter from the inside of the boat to allow the transom to dry completely. After a few months in the garage with a fan, I thought it was time to attack. Epoxy injection seemed the least invasive procedure. I started by drilling holes @ 3/16" diameter about 1" apart. Then followed by injecting West Systems epoxy from the bottom up. Some areas took little and others took alot more. I found this curious. So I cut out a small section of fiberglass from the inside of the transom and found some really, really bad wood. This broke my heart as I've smoked many cigarettes while starring at this boat contemplating repair possibilities. So how can I access this transom from the inside for total Transom replacement? Unfortunately, there is simply no way. There are two "blocks" in the way not to mention the splash-well itself. On the inside of the transom are two supports, one on each side of the boat. They are nothing more than supports that tie from the transom, to the side walls of the boat and then back into the floor. I initially though I'd cut them out and simply glass them back in after the internal Transom replacement, but I'm no glass expert. How could I equal the factory glass strength? So I was thinking of popping the top half of my boat via come-alongs in the ceiling of my garage. Obviously I'd have to drill out all the pop rivets around the perimeter of the boat and pull the bump stripe. This seems the only viable way to access my Transom without seriously inhibiting factory integrity. Any suggestions or directions would be appreciated....Please see attached pictures. Note the support block in the first photo. The second simply shows the Transom from the back to note the splash-well.
