chad913
Thread starter- Joined
- Mar 14, 2011
- 73
I need help on how to change my impeller on my 1988 85 hp force outboard. Its on my 1988 bayliner Capri that i am restoring. After forever it finally started but no water spraying out of the two holes. I added a tell tale and haven't tried it yet.I took the little cover off and looked behind the thermostat and it looked kinda rusty and dry. I started it yesterday so it should look better in there than that i would think. I have only cranked it on muffs. I wanted to get it running before i started putting down the floor and getting the inside buttoned up. If anyone knew were to get a impeller kit cheap online and maybe knew the one i need would really help. Also will i need a gasket when bolting the lower unit back up?
