1988 force 50 hp installing tachometer
goodtimesfishing
Installing tachometer(20 pole) on my 1988 50 hp force and just want to be sure of something. I know to hook the purple wire to the signal contact, the ground to the ground, but the bat AND the contact for light, can they come from the accessory of switch? I am assuming so or else the maybe the BAT. goes to battery and the light to accessory. Quick reply would be great as I am about to go out and install that and volt meter. I just want to be sure as I would hate to fry this tachometer as it was not cheap.
Re: 1988 force 50 hp installing tachometer
the batt and light wire should be hooked up to the ignition switch. So wene the key is in the on position so is the tach.
ahickman
Thinking about installing a tachometer in my 88 125 Force. What gauge did you choose?
I put the oem gauge in it. wene i bought the boat it did not have one. I bought my off of ebay. This are pretty good gauges. Ive never had a problem out of them. the item number for ebay is 190492989570
SweeperForce
I wired all the backlight of each gauge into the nav lights.
