1988 Rogue 2420
kcassells
Scott what are you screwing the dura brite snapa into? Did you have to add a pc. of wood or material to secure to?
the ceiling / upper deck is cored with 1/2" of balsa with 3/16" of fiberglass on the top and almost an 1/8" of glass on the inside.
spring loaded plungers securing the cockpit cushion over the porta-potty
The admiral already started adding decorative pillows....
had some buds come over and help with a few things....
washed off the foredeck
washed out the cockpit
installed the remainder of the interior....
only the one cushion over the motor is currently the original. I have the new one, finishing that tonight.
tpenfield
Looking Good, Scott.
When you we get to see a 'splash' . . . it must be soon :) :thumb:
tpenfield
It will be splashed with a smashed . . . :eek:
I hope the finger is going to be OK.
oral applications of whiskey.....
forgot to post these pics the other day.
installed the breathers. used an old hot-rodders trick. make a stand-off pipe and stuff it with fiberglass screen material (or brillo pads) the oil vapors collect on the screen to become droplets and run back down into the motor vs becoming droplets on the breathers and running down the outside onto the valve covers
and the drive prior to installation.
Going to try to wrap the boat up early this morning to take it with us camping, however realistically, may need to finish it Sunday when we get back.
kcassells
Looking good old man! Concur with your medical issue remedy for smashed finger. Have a good weekend away.
Drive on....
props mounted.....
motor didnt want to start easy, no squirt from accelerator pump. sticking check valve in Accelerator pump circuit - fixed
need to re-mount the carb and check for fuel leaks
intermittent power to the trim pump, that is the next thing to trace down....
have a tick in one of the valve rockers, that is on the list......
only crazy if it didnt work.
couldnt get the drive all the way down to set the trim indicator.....
so.....lowered the ground under it
friday some guy blows a stop sign in front of Tammy.......
spent Saturday tearing the garage apart looking for things to go back on/in the boat
discovered the carb accelerator pump wasnt squirting.
the check valve in the bowl was stuck along with the check valve at the discharge
fenders and PFD's
alldodge
Bummer on the car, hard place to fix also
Carb, motor tick, like they say need to use machinery or they act up. Some day it will splash :thumb:
that is the car that hit us. the bumper on the truck is what got hit. I dont feel sorry for the guy, he got the ticket. My buddy works at a GM dealer, getting a new bumper at his cost.
the tick was adjusted with 1/8 turn of the adjustment nut on cylinders 4 and 5
PFD's and fenders already stowed
