1989 Astro Quick Fire
Texas Cowboy
The trim control switch on my throttle control arm stopped working. Does anyone have any ideas why? Is there an inline fuse? HELP NEEDED!
Renken2000Classic
Could be a lot of things. The wires on mine got messed up not too far from the switch there (pinched or insulation chaffed or something; can't remember). So the damaged area was pretty easily accessible. Switch was still good.
mr 88
A test light is in most boaters tool boxes . Are you getting power to the switch ? Do you have power coming out of the switch or ower at the trim pump . Your switch may be fine , you could have a bad solenoid on the pump a bad connection , worn wire or bad switch . All traceable with a test light .
bajaman123
It's almost ALWAYS the switch in the throttle arm...they tend to come apart/fuse/burn wires after a certain age. As others have noted, testing reveals where the problem is. There are literally dozens of YouTube videos about how to test these issues. Just remember 'green for grass/ground, blue for sky' when you are manually testing your trim pump...e.g. green is for down, blue is for up. THIS is where I always start when helping people address "trim issues". Good luck!
Texas Cowboy
Thanks!
Texas Cowboy
Thanks!
