1989 Barrett's Success 200 4.3L Cobra
REM 6824
Took boat out this weekend. Somewhere between leaving the dock and returning some 4 hours later I lost reverse. No grinding, just when moving shifter in to reverse the boat would move forward instead of backwards.
Reverse was working when I left the dock. Cables are attached to the bracket mounted on the intake.
Looking for some guidance.
Thank you in advanve
kpg7121
Remove the shift cable from the braket, pull on the cable & see if it shifts into forward. If it doesn't you'll probably need to replace the cable & do the shift system adjustments. Have you done any cable adjustments before this or is this a new issue?
