Big Fish Billy
- Joined
- Dec 31, 2009
- 301
Re: 1989 Blackmax compression
Also could be piston topping out in chamber because of carbon on top...decarb is definitely worth a try....
If it were detonation it would really only do it under load. From someone who has detonated a few motors to death ...you CAN hear it and when you hear it , its too late.
Could be bearings, could be piston slap in a cold bore, could be a worn out piston or bore. rings could just be stuck. Chrome bore motors can have a bad bore or more re sleeved with an iron sleeve and saved.
I still think if it runs OK I'd just let it run if the bearings check out. Try the decarb.
