1989 evinrude 200 hp
SHERRY SAVAGE
New powerpack,new voltage regulator,new magnets. Motor still does not fire. Any suggestions on what else could be wrong?
Barnacle_Bill
Re: 1989 evinrude 200 hp
First make sure the emergency kill switch isn't on. If it is ok, disconnect the black/yellow wires going the the switch boxes and recheck. If you now have spark there is a problem with the emergency kill switch or ignition switch.
JB
I will put this in the JohnnyRude forum for you. Mercs are different than Evinrudes.
Go to the Engine FAQs forum and do "Outboard won't start".
Tell us what you find out.
clanton
Did you check the stator output?
Benny1963
pull red plug jump it at selinod if it doesnt fire dva stator and go from there if shows voltage at stator then check for grounded wire in powerhead wireing
and test rest of elec with dva
SHERRY SAVAGE
Weird thing happened to me.New powerpack,new voltage regulator, new magnets.Engine still does not fire.Raised motor with tilt and it would fire and lowered motor and it would fire the next day.I am scratching my hair out right now.Messed up wiring somewhere I guess?
Barnacle_Bill
There is a mercury switch bolted to the motor that prevents you from starting it when raised. It may have been stuck and raising the motor freed it.
You might want to check it as the motor shouldn't fire when raised.
