FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
First make sure the emergency kill switch isn't on. If it is ok, disconnect the black/yellow wires going the the switch boxes and recheck. If you now have spark there is a problem with the emergency kill switch or ignition switch.
pull red plug jump it at selinod if it doesnt fire dva stator and go from there if shows voltage at stator then check for grounded wire in powerhead wireing
and test rest of elec with dva
Weird thing happened to me.New powerpack,new voltage regulator, new magnets.Engine still does not fire.Raised motor with tilt and it would fire and lowered motor and it would fire the next day.I am scratching my hair out right now.Messed up wiring somewhere I guess?
There is a mercury switch bolted to the motor that prevents you from starting it when raised. It may have been stuck and raising the motor freed it.
You might want to check it as the motor shouldn't fire when raised.
