1989 Evinrude VRO 70hp fuel pump switch
joho5
I want to eliminate potential problems now and in the future, so do they sell regular fuel pumps for this model where I just premix the gas...that is what I do now anyway and just have the oil line plugged.
I am having symptoms of a fuel pump problem now and just wanted to replace with a cheap regular fuel pump.
I cant find one for a 70hp though.
tashasdaddy
Re: 1989 Evinrude VRO 70hp fuel pump switch
this one will work and will use the existing pulse line. just make a plate to mount it.
Part Number: 0385784
Description: FUEL PUMP AY
Pack Qty: 1
Dimensions: 3.50 x 3.50 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0395712,0398385,0433390,0438559
seahorse5
A regular fuel pump such as the one in the previous post isn't cheap, it's around $100.
Go to a 1983 parts book and pick out the fuel pump, hoses, and other parts needed to convert your 70hp to a regular fuel pump system. Make sure you test the boat's fuel system first for restrictions and air bubbles that will give similar symptoms.
tashasdaddy
the part listed above is for the 1983 70hp.
joho5
How would I check for bubbles? I cleaned the carbs but didn't rebuild them. I will probably do that along with replace the primer bulb to see if it cures the problem.
renvette2
Will this pump work for my 1991 60hp Johnson?
joho5
Pack Qty: 1
Weight: 0.44 lbs
TD, is there a sierra or aftermarket brand of this part that will work? Or anyone can respond...I have a confirmed vro fuel pump out...just runs the fuel out of the bowls and have to repump it with the bulb to keep going.
like say, this one
http://www.iboats.com/Sierra_18_735...2660523--**********.338693441--view_id.174138
joho5
bump, I was going to try and buy this part today and the marine shops in the area close at noon today, central time.
thanks guys
