boat restoration master
Thread starter- Joined
- Oct 3, 2010
- 4
ok so i bought an outboard from a guy and he said it ran i finally got it hooked up to my boat and all seems great except it wont start by not starting i mean the starter doesnt engage at all i have power to the motor where it needs to be i followed the yellow/start wire all the way to the starter solenoid and it does what its supposed to when i turn the key to start it it lights up but the solenoid wont engage to give power to the starter naturally i thought the solenoid was bad i went and got a new one and had the same problem i bypassed the the solenoid and the starter turned fine so pretty much i have my positive on one side of the solenoid and on the other is the wire to go to the starter and on top a little yellow wire that sends the signal to switch the solenoid to on and everything works except the solenoid wont give power to the wire to the starter and its a new solenoid so whats the problem? is it supposed to be grounded and if it is how? any help would be greatly helpful thank you
