1989 FORCE 85 HP WHAT'S IT WORTH ????
russ burke
All:<br /><br />I just water tested a 19 ft Spectrum alum, boat with a 89 Force 85 HP, it went well. The engine ran quite well and the lower unit lube is clean. What is a motor like this worth, with controls and all. I have a 88 yamaha 70HP with low hours I am thinking of swapping out. Any ideas or feedback would be appreciated.<br />Thanks<br />RB
Solittle
Re: 1989 FORCE 85 HP WHAT'S IT WORTH ????
You will probably get responses on the Force like "if it has been well maintained it is a good motor." I think the consensus will be however:<br /><br />"It is hard to get parts."<br />"They haven't been made in a number of years."<br />"Most marine mechanics won't touch them."<br />And the most common - "they are a piece of sh&t."<br /><br />I had a Chrysler years back (predecessor to the Force). I had no problem with mine but I remember asking a factory trained mechanics once of his opinion in the Chryslers. He said "Outside of the power head it is a fine motor."
roscoe
$600-$800 on ebay, parted out. About the same if sold whole.
ziemann
SoLittle pretty much hit it on the head....
D
DJ
Guest
That 70 is going to work its heart out on that Spectrum. It will probably perform about the same as the 85 Force though.<br /><br />Spectrum/Bayliner tended to underpower those boats, from the get go.
rodbolt
ill swap ya a Yugo with a bad tranny for it :)
