Just getting started on my transom / stringer / floor repair and thought you all might be interested in seeing the progress. I've been lurking here for over a year and have finally plucked up the courage to give it a go.
This started out with the boat taking on water. It always leaked a little bit, but it progressively got worse. Not knowing a whole lot about the internal structure, and unable to tell where the water was coming in I took it to a shop. They concluded that the motor mount had collapsed and was causing the transom to flex. They couldn't fix it, but knew someone who could. So I took it to him, and he wanted around $5k to do the work (the boat's only worth about 2500), and I had to pull the motor, and outdrive myself. So I started looking online to see what it would take to just do the whole job on my own. This web site has some great information. Thank you to all who have shared your experiences.
So far I've got the seats out, the outdrive off, and pulled the engine. I pulled the carpet back on one side to reveal the soft spots in the floor. The gas tank chamber is full of rot and mildew. The cover was collapsing into the floor as the supports are rotted as well. I could not believe that even though this boat has not seen water in over a year the wood inside the motor mount was still wet!! I was able to scoop in out with a screwdrive. It's like butter. This brings me to my first question: If the motor mount had collapsed to the point where the transom was flexing, how do I know how far it has to be built back up? I was thinking about taking a level and setting it on the sides (which don't look like they've been compressed) and measuring to the bottom of the hull to determine how high it should be when I rebuild it. Is this a good strategy?
Another question I'm pretty sure I already know the answer to: do I have to pull the cap to replace the transom? The floor feels pretty firm from the cockpit up, so my thought was to start at the aft and work up until I get solid wood and then just replace it from there using epoxy to mate with the old. What do you guys think about that strategy?
Thanks,
Robert
PS. I've attached some pics of the damage.
Thanks,
Robert
