bowhntnfishinSD
- Joined
- Jun 25, 2008
- 1
Hey all,
My motor has always had some Idleing issues, and my prop got spun. So I took my motor into see what was up, the shop told me the prop was spun and the electronics were bad, causing the idle problem. Ok, since I just had the carbs rebuilt like two months earlier I figured that sounds resaonble enough. The motor always had great power so I thought new electronics, and rebuilt prop I'll be back on the water with no worries Right. Wrong, I took the boat out immediatly after they were done with it. The motor now a full speed is more like No wake speed. It feels and sounds like thats all the power is has. I even checked the carbs to see if the throttle cable was misaligned and not opening the butterflys wide open. Well they were wide open and that is all the power my motor is producing. So I took it back to the repair shop and they said don't know it ran fine in the shop, then he pulled a spark plug out and ran a bore scope into a cyclinder and said oo look the cyclinder wall is scraped. Something must have happend between there and the lake and they would have to charge me more to repair. I said I don't think so it ran fine, had Idling issue and now it don't run at all. Anyway they said they weren't going to fix it unless I pay. So Lake Sharpe Marina- Pierre, SD watch out for these guys if ever up there bunch of crooks. Anyway, i need to diganose my issue. O yeah they didn't fix my prop either, they just painted it!!! Still spun.
Just need to know what to do about the power loss, all I can tell you is they replaced the electronics
