Re: 1989 Sea Ray 180 transom replacement question
Well, another weekend and a little bit further forward. More sawing out to remove the rotten floor, stringers and bulkheads. This weekend it was the bow end and it was hard work. Very little work space and a lot of the wood was in good condition, but had to be removed to get at the rotten floor. Had an unfortunate oops moment today when I cut an 8 inch line through the hull!! Read on another thread, that it's not the end of the world and is an easy fix. I have a small crack on the hull to fix as well. There is a small amount of sawing still to do (more to reduce stringers that are still sticking up) and then I can begin the grinding. That's looking like next weekend and I don't really feel like starting work after work and getting all hot, dirty and itchy!
Couple of things I noticed about Sea ray construction, which is obtuse to say the least. The ply upright panels for the dash and which form the back reast for the bow seats are glassed in to the floor, yet bolted to the dash panel. A better design would have been a lower bulkhead and then bolt the panel to the dash and to the bulkhead panel. That way, replacing rotten wood is a quick fix. I may do a re-design on that when it comes to re-construction. It is the same with the box panel/seat bases at the back which go all the way to the transom and are glassed on yet bolted to small brakctes at the cap top.
Oh and one last thing. The cushions are attached to the dash and cap by blind stainless steel bolts tightend with stainless steel split washers and MILD STEEL washers. Guess what was all corroded. Talk about spoiling the ship for an hayporth of tar!!
