Re: 1989 Ski Brendella (boat restoration progress)
Take it one step at a time...
Don't assume anything, especially when it comes to boats...
First off, get a test light...check for power at the coil, both, with the key in the run and start positions...
Also, invert your test light connection, put the ground clip on the positive terminal of the battery, and check that you have a good ground...
Check for a good spark at the coil and at the plugs...
Check that the carburetor "injects" a stream of fuel into the venturi when you operate the throttle...
Put the engine on Top Dead Center on the Number One Plug and verify that your distributor rotor is pointing to the Number one Plug Connection on the cap...
Check your compression...
If you have all three, spark, fuel and compression...the engine will start...it may need further tuning and/or adjustment, but it will start...if any of three are missing or inconsistent, you will have problems...
Let us know what you find...
BTW, great looking restoration so far...
GT1M
