1990 Black Max 200 hp on 21 ft Norriscraft-dies when put in gear.NO holeshot. HELP!!!
DWfunk
I bought this boat and it ran great. Took to lake and it wouldn't hardly plane. Found a mousenest in back of motor cowling. Got it out, took carbs off and had them cleaned and rebuilt in a tank overnight, had fuel pump rebuilt, link and sync plus new plugs. The boat still is sluggish out of hole with low rpm's and then gradually picks up rpm's and takes off. Will not idle or start unless motor is trimmed up level and even then if you put it in gear it dies unless I am giving it fuel with the hotfoot. once on plane it runs smooth and clean and fast. I am going crazy with this. I can put plugs in it and it does great for about 2 or three times taking off, then its back to same old thing. it also smokes blue really bad for about 15 seconds. I mix oil and gas 50:1 and use pennzoil synthetic. I use 87 octane ethanol free gas. I looked at my fuel filter which appeared to have hair and little black specs in it but could still blow through it pretty good. I have a generic primer bulb on it but don't know if that is the problem. I have a bob's racing foot with low water pickups on it and a mercury trophy plus 4 blade prop on it with a 25 pitch. This engine should idle and not shake hard like a plug isnt firing all the time. on slow idle with foot on gas sometimes it shakes and knocks like crazy. Compression is good on all. HELP!!!! 606-233-4486 call me anytime, shane is my name.......I would love to fix this. could be enricher valve allow too much fuel and flooding it?
Dave1027
Re: 1990 Black Max 200 hp on 21 ft Norriscraft-dies when put in gear.NO holeshot. HEL
Not the primer bulb or filter. If so it would be affecting criuse. Your issue seesm limited to the idle circuit in the carbs. First thing to try is to open up each idle mixture screw a 1/4 turn and test. If it improves but still not satisfactory open up another 1/4.
DWfunk
Where is the idle mixture screw? What does it do? I was told there were no adjustments on these carbs. I had them taken off and put in a tank overnight by a mechanic who is supposed to be very good. He put new gaskets on them and put them back on. He said the needle and floats and etc. were in good shape. Things were great until the mouse nest and ever since, it hasn't been right......
DWfunk
Faztbullet
Check you spark as it sounds like its only running on one bank then kicks in on high side of stator. Could be mouse chewed stator wire in half also....
DWfunk
How do I check it?
