1990 Force 120HP #2 Cyl zero compression and upon opening piston shows damage
gica
New piston might be 3.365 /3.367 " at the rings.-----3.372"at the skirt.-----Aluminum pistons expand at around 0.000012"/ inch / degree F ------New pistons are tapered and sized with clearance when cold.------When engines run clearances , I do realize I cannot use standard size pistons on the oversized #2 cyl. I am trying to understand why I cannot use oversized pistons if I actually have the B or C model.
Thanks for that I think I understand it. But if I have the A model then the motor is junk. Bor at 3.312 is way below the .030 max oversize piston posibility. But the B or C models can be bored to within the oversized specs since the standard sizeis 3.375.
I did not see any listings for 120hps.
So new Force motor is out of the question.
I don't even think I would get another Force though I have now learned a bit of what it's all about as far as adjustments and tore down.
gica
I couldn't wait so mine is a B so 3.375 standard. I should have all the way to 3.410 to install up to .030 oversize pistons right?
I could be wrong but this is what I read.
gica
This thread mentioned what I stated
So now I want to know what I can do short of getting another engine.
The one thing I still don't know is the oversized rings, I goes to get closer to the ideal gapin an oversized cylinder bore you need a larger ring. Would that go hand in hand with the piston size say .010 piston .010 ring?
jerryjerry05
Probably need to go to .020 piston and rings.
.010 rings don't fit good on a .020 piston.
Buying another Force?? If they've been maintained right then they will last as long as any other motor.
Proper maint. is the key.
I had 4 88/85hp. They had over 2k hours and the transom gave out from salt water. They just don't hang good when used in salt.
Same as the 125 had 2 and had to retire them because of the weak transom material.
But buying a 35 year old anything isn't a good bet
The following is my OPINION
Buy any brand that makes a EFI
The HPDI is much better on fuel but crazy expensive to fix and pay the mechanic, a regular shade tree (like me) can't fix them.
Yam ,Merc, Suzy all make great motors as they use the same technology.
Good luck.
Honorary Supreme Mariner
Measured a brand new piston for a Mercury.-----It has 0.008" taper.------If a piston is way too loose in the bore than crankcase compression can be lost right out the exhaust ports.-----Fitting new piston rings in old worn out grooves is a mistake as well.----This whole concept of a 2 stroke engine is not well understood.------Piston has to do double duty.-----Compression on the downstroke on the bottom.----Compression on the upstroke on top.------Proper fitting is important to get a " wow factor " when owner hears a rebuilt engine run !!!
gica
I totally agree and
I totally agree and speaking from experience I do remember installing pistons and rings the I thought were borderline good and the end result was not the best compression. I don't have much experience using oversized pistons.
That said what do you recommend in this case. Jerry mentioned .020 with the same size rings. Let me measure tye pistons I have. You say they will he 3.365.
They will be 3.365 or less at the rings ----They will be 3.368 / 3.367 at the bottom.-----Piston clearance is determined with the measurement at the bottom!
gica
At the top it shows 3.360
Bottom 3.373
So with a bore of 3.375 we can see the clearance that the factory accept.
Compression was 125 and 128psi
Recheck your measurement at the bottom.----Piston might be out of round.-----When it left the factory it would have been 3.371 / 3.372?
gica
I think I need the .010 which will he bigger than my bore at roughly 3.3820. It will he bigger which means I still need to take of some material.
The bore has to he 3.385 right?
gica
Ok so I need to do this properly, so I am following this video to use a micrometer and dual gauge and see tye real status of each cylinder. I zeroed everything. I will set it at 85mm and see what's going on. I am sure it's out of round more than .002
So honing is in order. On #2 I want to see how much material I took of. The telescopic measure I took of 3.382 is ball park don't know if it's true 100%.
And with those measurements I can decide which way to go. I do need new stones though the 240s are 90% gone. I probably should have gotten 180s and 300s for more efficient work
Make sure you measure diameter at the very bottom of the cylinder.-----Using honing stones to take out 0.010" is not what is consider " best practice "-----Now I used to work in a factory where tolerances of + /- 0.000020" could be held.----I do know what measuring is all about !
gica
My dial gauge is not top notch so ball park set it at 3.375 and went up and down from there
On #2 some minor error adding .00005
Don't know how the telescopic dial found 3.381
gica
So I am thinking to take the block to a machine shop to do proper boring but I need to buy the OS piston and rings first. Which size do I get based on the measurements, .010 or bigger?
Nordin
Take the power head to a machine shop and have it measured by them.
Then order over size piston and rings from the measurement from the machine shop.
gica
Ok found a machine shop with a guy that told me to get the .020 since he didn't measure it he said that is safe to get the 0.020.
But I measured it and want to get the 0.010
Only number 2 has been hone to do understand the damage.
Also he said to do them all.
So do you guys think I can get away with .010 or jump straight to .020
I wanna have room in case pistons get damaged.
