1990 v-200 Stator Test? (5454A34)
danamul1977
I've been having problems bogging down at 2500-3000 rpms under load so I wanted to test the stator. Wondering if these #'s are to low and would cause the problem. Book says (between blue and red wires, 4450-4600ohms) mine is 4130. Between blue/white, red/white 4450-4600ohms, Mine is 4170. Everything else tested ok, (triger was ok). Would this cause a high speed problems under load.
Also wondering if it matters what yellow stator wire goes where on the rectifier. Is their a high speed wire and low speed? I need to know how to reconnect it, they seem to be the same. TY
Dukedog
if it won't pass tha ohm test its weak.... bad high side usually won't let tha motor turn over 3 grand at most...
yellows are chargin' circuit.. either pole on rectifier long as its not tha one marked +.........
strange, not many 16 amp '91 200's around.. same stator used ona 2.4 bridge port!
