Captain Koz
Thread starter- Joined
- Nov 26, 2008
- 47
Hello,
I have a TXEIC, 1991 225, Johnson. for fun I buy tired motors and refurbush them... honed, new rings, all soft goods replaced, new check valves, etc. I am an advanced tinkerer and just short of professional. Ive refurbished about 9 early 90's loopers in the last 3 years. I feel I have more than a clue about these.
Anyway, I just got this one together. It was a touch hard to initially start on the stand but when it started it ran with no problems. I mounted it to the boat and started it in my driveway and she started and ran perfectly without a glitch. Next day I get to the dock to finally get out there and fish...and NOTHING. Not a backfire. Nothing. No spark. Get it home and start parts changing. I have a stock of used parts so I start changing until I find the problem. Basically I had no spark at all. I disconnected the red plug to isolate the motor. I plugged in an in-line spark test light that clips into the spark plug lead, then to the spark plug, thus flashing as current go through the spark plug lead. The only hint of of light I got was at the moment I jumped the starter from the red lead to the yellow/red on the solenoid. It was not the timing of the base/flywheel, it was a wierd initial blip as soon as I would jump the wire, then no lights to follow at all. Strange and unprecedented I though.
So I switched the stator, re assemble, try to start... nothing. same for the timing base, same for the powerpack. So now the motor has a different (all used parts) stator, powerpack and timing base.
I hooked up the rectifier, jumped the starter solenoid and BROADWAY... i got bright, timed light from the test light and a quick sputter or two as if she wanted to start. Great I thought, Its the rectifier. Case solved.
So I then install the original timingbase, stator and powerpack, and install the different (2nd) rectifier. Put it alllll back together, hit the key.... NOTHING! F@(#*$&#(#(@)@((#*#*K!
I get out the ohm meter. the yellow/silver lead of the rectifier to the casing shows nothing when it should show something (according to CDI website). The plain yellow lead shows something (in the 140's i believe). Same thing on both rectifiers. I have a 3rd rectifier which shows numbers (140's) when attached to either yellow lead (red probe on ohm reader) and the black probe to the casing.
So what is blowing my yellow/silver lead to the rectifier? Im assuming I should suspect the stator? Im on my last used rectifier so I have one last shot before It costs me.
Thanks for reading!
Thanks for reading!
