1991 6.0-HP tell-tale sometimes
whiskerchasin
This outboard is new to me. I have ordered an impeller, waitin on it to arrive.
I have the LU in a water container(not on muffs). When I start this motor for the FIRST time each day there is a good stream of water coming from the tell-tale, but after I shut her down and restart it no water comes out. It has done this 3 times already. Has anyone seen this happen before? Thermostat maybe? I've read it's good measure to install a water pump kit, wish i'd read that before ordering just the impeller.
Daviet
Re: 1991 6.0-HP tell-tale sometimes
I think you are on the right track with replacing the water pump.
whiskerchasin
Ok thanks once again Daviet.
It just baffles me that once it's warm it doesn't pump.
Daviet
The tell-tale is before the thermostat, it is an indicator of the pump output. Replacing the impeller is the first place to start.
