Update 10-16-2010 Part2
Started with the transom lamination. Scored both pieces that where to be laminated. Something my father taught me when I was a kid. Aids in the bonding process. The epoxy lamination process was as follows. "Paint" both faces to laminated. Wait 10-20 minutes for wood to suck in epoxy. Recoat one piece lightly, (to fill any areas where wood sucked up all the epoxy), and the other piece med/heavy coat. Lay together and screw together every 8-10 inches starting in the center moving out. Wipe the epoxy the squeezes out and coat edge. (made a mess of the floor, and had horrid time with the mess the rest of the night. Hint "USE A DROP CLOTH ON THE FLOOR". I know my shoe bottoms will not rot ever.
Here is a pic of the laminated transom before laminating and after.
Next I tab'd the bottom and top edges with the 6" 8.5oz. This was a new experience. I would recommend that all edges have a minumum od 1/2 radius on it to aid in the mat laying down on the wood. If not the mat lifts from the wood. It took me and hour of constant rolling to get it to stay down.
Next I started laminating my stringers. I did not take and pics due to they are following the same process as the transom. WHen I bedd them in the boat I will post pics. I did how ever bed/laminate the transom to the hull. This was after glass'n a piece of 1708 biax to the wood. This was between the wood and hull on hte wood. I coated again the wood and the fiber glass in the boat with normal epoxy. The layed the 1708 and spread epoxy resin on top and the it saturate throu the material. While this was setting up. I mixed some PB epoxy and spread on the transom hull and bottom. Placed the wood in the boat and proceeded to screw/clamp the transom in place. You will notice a void under the transom wood. This has not been filleted and I want to fill to drain plug with PB epoxy before tabbing the transom to the hull. So this void will get filled. Here are some more pics.
I did not get the string bedded like I wanted but I have time this afternoon to get it done. Worked this last night from 7:30PM to 2:30am. That is what I got done. I probably could of done more if I had the heat on at first but I wanted a slow cure on the transom lamination. Let the wood soak it in.
Lessons learned from last night.
1) Drop cloth is absolutely needs to keep mess down.
2) Have a full box of disposable glove. Going to go throu them.
3) Anywhere you are going to wrap mat, it needs a fillet.
4) 1708 Eats large amounts of resin for wet out. About 250ml/1sq/ft
5) To make PB epoxy take alot of Cord Silica
6) 10 degrees in temp diferences make huge curing time change.
7) Have huge amounts of Patience when glass'n
So this afternoon thing to do.
1) Fil/fillet the transom
2) Finish wraping the bottom of the rh stringer.
3) Bedd both stringers to hull
4) FIllet the strings to the hull.
I'll keep you posted. Don't feel to bad with only 5 hrs sleep. Kind of like waking up the next day still drunk from the night before.
Jeff
