j_k_bisson
- Joined
- Oct 6, 2010
- 1,082
Update 10-24-2010 Glass'n done!
We'll try this again for the second time. Pressed the back button and lost everything. Anyways, a very good night last night. Finished the glass'n on the hull!!
I was even able to start the reassembly. Only put the fuel tank back into place. But it's a start! Of coarse I could not find the screws and bolts that held it into place. Maybe after I clean the garage this afternoon I will find them. If not off to buy new bolts. I attached two pics. One showing the tank into place with the same clearence as original, and a pic of my work bench. I included it because I need to find the spare set of car keys that has to be on there. Can not find them in the house!
I started the night by painting/coating the wood to be installed with thined out epoxy. I thin the epoxy a little to aid the wood in sucking up the resin. After that was dried/hardened I made a batch of PB epoxy and floated the wood into place. Next filleted and tabed it. Used 6" wide 1708 biax for the tabing. After I started mixing up a batch of pigmented epoxy for coloring the area of repair. It did not come out very good. I am not happy at all with the outcome. Check it out. This is only 5 minute after application. I looks alot worse this morning. It all ran down the vertical wall.
I was thinking of trying something new. Seeing that pigment really thins out the epoxy mixture. I was thinking of adding a bit of cordical silica to thickned it to a slight gel. Then crank the heat in the garage to 85-90'F and shoot this mixture through an undercoating gun where I want it. Anyone ever try this? Pleaswe let me know, will not be doing this for a couple of days (Monday/Tuesday).
The plan for this afternoon it to clean the garage.
Also for those of you who are wondering what materials I have gone through here is the list so far;
1) 7.5 gallons of epoxy
2) 8 Yard 50' wide 1708 biax
3) 3 yard 12" wide 1708 biax
4) 5 yard 6" wide 1708 biax
5) 1-50 yard roll 8.5oz 6" wide CSM
6) 1 pd cord silica
7) 32 mixing pails
8) 2 gallons of acetone
9) 2 flap wheel ginding discs (40 grit)
10) 2-25ft rolls for wax paper
11) 4-100pcs boxes rubber gloes
12) 6 tyvec suits (disposable)
13) 2 pairs of good sissors (cutting 1708)
14) 2 sets of epoxy pumps (only last a couple of days in epoxy)
A few other small things I can't think of.
Do not buy the rollers for glass'n have not used them at all. Waste of money.
Thats it for today
Jeff
6) 1 pd cord silica
7) 32 mixing pails
Thats it for today
Jeff
