1992 Johnson 150 power problem
DIAT
1992 Johnson 150 model number TJ150GLENC motor. The motor has little power and dies at take off when given full power. I pulled the plugs which are new (have less then 3 hours) and its running rich on oil. At low speeds you can smell gas and it now its starting hard. Any recommendations would be great. Thanks in advance!
emdsapmgr
Re: 1992 Johnson 150 power problem
Check each plugwire for spark. A spark checker or an inductive timing light should help you determine the quality of the spark on each plugwire.
