1992 Johnson 8hp will not idle
kenww
I have a 1992 Johnson 8 hp that will not idle. It sounds like it runs out of gas. I have put a new fuel pump and carb kit in. new tank and hose. I set the air seat at 2 1/2 turns. If I pull the choke out when it starts to die it picks up again. Help!!!
Ken
Monte1961
Re: 1992 Johnson 8hp will not idle
Ok but have you readjusted and fine tuned low speed jet yet? It's probably running to rich? Post back results.
kenww
I didn't think it had more then one jet
Monte1961
8 hp carb.jpg Look at item # 15 Low speed jet
kenww
Thank you I will try that. Ken
kenww
That's the same one that i seated and then backed off 2 1/2 turns
Monte1961
Ok that 2.5 turns is just for starters, it isn,t properly tuned yet. Start motor and allow to warm. Now working between Idle screw and item # 15 low speed jet, Work between them to get the lowest maximum rpms you can get! Now turn item Item # 15 out 1/4 to 1/2 and leave it alone. Restart motor if you have to and set idle screw to recommended rpm in gear. Post back results.
kenww
I found a crack in the float bowl. thanks for the help. Ken:)
